Boas tardes novamente!
Como o meu carro soluçava (como ja disse no topico anterior), fiz um teste VAG-COM.
Detectou um erro... alguem me sabera dizer o q e'?
Aqui Vai o resultado, obrigado:
Re: Boa tarde! Audi A3 (o carro soluça)
boas noites amigos!!!
O luis ligou-me esta tarde que estava com problemas com o argolas...
Ora então ligamos o argolas a ultima versão do vag-com e o resultado foi...
Monday,23,May,2011,21:57:47:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 168970km/104993miles
Address 01: Engine Labels: 06A-906-019-AEH.lbl
Part No: 06A 906 019 D
Component: 1.6l R4/2V SIMOS HS2153
Coding: 04000
Shop #: WSC 06313
VCID: 244CEECED881E93C
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
VCID: EED84CE6C6CD936C
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 B
Component: A3 KLIMAVOLLAUTOMAT_D73
Coding: 03140
Shop #: WSC 06313
VCID: 2756F9C2A9B70224
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 601 A
Component: AIRBAG VW3 V01
Coding: 00065
Shop #: WSC 06313
VCID: 254AF3CAD3BB1034
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 860 A
Component: AB-KOMBIINSTR. VDO D11
Coding: 00142
Shop #: WSC 30011
VCID: 366824867E1D6BAC
Part No: IMMO
Component: IDENTNR: AUZ7Z0V0163551
IMMO-IDENTNR: AUZ7Z0V0163551
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
VCID: 56A88406DE5D4BAC
16 Faults Found
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking; Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking; Passenger Door (F114)
01365 - Lock/Unlock Switch; Interior
28-00 - Short to Plus
Coding: 04000
Shop #: WSC 06313
Readiness: N/A
Coding: 03604
Shop #: WSC 06435
Coding: 03140
Shop #: WSC 06313
Coding: 00065
Shop #: WSC 06313
Coding: 00142
Shop #: WSC 30011
Part No: IMMO
Coding: 00000
Shop #: WSC 65535
16 Faults Found
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
