ajuda em erro
Quando instalas o vagcom, no fim ele não pede para instalar os controladores?
O cabo ao ligares ao pc e ligado na ficha OBD por norma instala sozinho.. após isso fazs o TEST a ver se dá tudo OK. Depois clica em ABOUT e vê o que lá está escrito.
pede e eu ja instalei so nao sabia a ordem em que metia os cabos
ja deu correcto os cabos. agora fiz um scan e parou a meio e diz
sorry! this function requiresa licensed interface
e apareceram estes erros
Wednesday,15,February,2012,23:19:44:10074
VCDS Version: Beta 11.8.0 (x64)
Data version: 20110831
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
VIN: WAUZZZ8P37A044790 Mileage: 114340km/71047miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No HW: 03G 906 018 DH
Revision: --H22--- Serial number: AUX7Z0F6FNV09K
VCID: 55A585678218
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E1DBFF6CAC
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
Component: KlimavollautomatH18 0300
Revision: 055047 Serial number: 8P0820043P
VCID: 397D29D70E40
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006024234
Coding: E5885F078214100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408B44336D9A
Subsystem 1 - Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
3 Faults Found
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 193
Mileage: 111222 km
Time Indication: 0
Date: 2011.12.18
Time: 13:31:00
Freeze Frame:
ON
Voltage: 11.35 V
ON
ON
OFF
OFF
OFF
00061 - Footwell Lights
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 180
Mileage: 108004 km
Time Indication: 0
Date: 2011.10.10
Time: 00:35:00
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 57
Reset counter: 220
Mileage: 109721 km
Time Indication: 0
Date: 2011.11.24
Time: 12:51:00
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
OFF
Amigo apenas tens ai umas lampadas fundidas, nada mais...
Mas continuas com problemas no vagcom.. Vai ver no ABOUT e verás que diz em letras vermelhas que o programa não está registado.
ya. diz que nao esta registado. burla?
Nops...
è apenas mais um cabo igual a tantos outros que não sendo comprados na fonte ( Ross-Tech) estão sujeitos a este tipo de situações.
Por mais disparate que pareça ser, testa noutro carro. Tive um cabo que de vez em quando dava para ficar como esse e mal ligava noutro carro ele se auto-registava :p
Nops...
ka truque fixe:lol: ou seja a suluçao e comprar outro?
ache que a situaçao é mesmo saber onde comprar de confiança. mesmo assim ainda tenho que contactar o vendedor porque ele deu me os papeis de garantia de 2 anos do cabo. mas ele nao funcionando secalhar vai é despachar me
mas depois de experimentar noutro carro ja voltou a dar no teu?
O melhor é falares com o vendedor... Se tem garantia, só tem que trocar..
Por acaso não instalaste mais nenhuma versão anteriormente a essa? Se for o caso aconselho-te a desinstalar todas e quaisquer versões, se possível até podes ir para um ponto de restauro anterior a essas instalações, pois se instalaste controladores várias vezes, pode estar aí o problema (falo por experiência própria). Depois de fazeres isso, voltas a instalar o software, controlador no final do software e fazes o que o Jimy te disse, mas antes de te pores a fazer scan verificas o TEST e o ABOUT. Caso continues com o mesmo problema, tenta falar com quem te vendeu, para te dar o auxílio devido ou money back ;)
