alguém me podia dar uma ajuda a descobrir estes erros
o carro é um audi A3 8l 1.9 TDI de 2002
os 2 primeiros já descobri.
Thursday,28,March,2013,13:42:10:10074
VCDS Version: Release 908.0
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Control Module Part Number: 038 906 019 CK
Component and/or Version: 1,9l R4 EDC 0000SG 1477
Software Coding: 00002
Work Shop Code: WSC 06435
Additional Info: WAUZZZ8L32A030166 AUZ5Z0A8215122
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Control Module Part Number: 8D0 862 257 B
Component and/or Version: ZV-Pumpe, Funk D16
Software Coding: 14913
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Control Module Part Number: 8L0 920 900 M
Component and/or Version: KOMBI+WEGFAHRS. M73 D07
Software Coding: 04140
Work Shop Code: WSC 00058
1 Fault Found:
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
2 Faults Found:
4 Faults Found:
35-00 - -
00955 - Key 1
00956 - Key 2
1 Fault Found:
