[AJUDA] Erros VAG-COM A4 B6
Boas PPL,
Hoje um amigo meu pediu-me para ligar o Vag-Com a carrinha dele.
O problema que ele me falou que a carrinha tem é ter o compressor do AC avariado, inclusivé nem está lá a trabalhar a correia.
A carrinha é uma Audi A4 B6 1.9 TDI 130cv e apareceram-me os seguintes erros:
Thursday,01,January,2009,19:10:02:26365
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 116730km/72532miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00002
Shop #: WSC 24384
WAUZZZ8E03A006667 AUZ6Z0B0110549
1 Fault Found
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 M
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
5 Faults Found
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01809 - Actuating Motor for Temperature Flap; Left (V158)
01274 - Air Flow Flap Positioning Motor (V71)
01592 - Air Quality Sensor (G238)
37-00 - Faulty
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 00001
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AE
Component: Komfortgerát T01 0316
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
4 Faults Found
01801 - Door Warning Lamp; Drivers Side (W30)
57-10 - Electric Circuit Failure - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01331 - Door Control Module; Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
01561 - Left Rear Door
61-00 - Won't De-Safe
