AJUDA Erros Vag-Com
Alguem me pode ajudar com isto? Dizer algo mais preciso?
Tenho a luz de motor laranja ligada e deu-me este erros.
Obrigado,
Friday,20,February,2009,18:11:05:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 76 7D
VIN: WAUZZZ8P24A152734 Mileage: 151710km/94268miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC G000SG 5705
Coding: 0000072
Shop #: WSC 00066
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1323 /min
Torque: 92.0 Nm
Speed: 60.0 km/h
Load: 20.4 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
Mass Air / Rev.: 335.0 mg/str
Mass Air / Rev.: 565.0 mg/str
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.LBL
Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
Component: KlimavollautomatH12 0150
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 150329 km
Time Indication: 0
Date: 2009.01.16
Time: 12:39:23
Freeze Frame:
Voltage: 11.80 V
Temperature: 26.0°C
(no units): 126.0
(no units): 228.0
Temperature: 4.5°C
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H30 0701
Coding: A68A5F0082141000000000000000000000
Shop #: WSC 00000
Part No: 8P1 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.LBL
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
Shop #: WSC 06435
Address 16: Steering wheel Labels: 8P0-953-549.LBL
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H11 0020
Coding: 0002042
Shop #: WSC 06435
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0140
Coding: 0004003
Shop #: WSC 00078
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Coding: 7D0F0F4A070100
Shop #: WSC 06435
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 151668 km
Time Indication: 0
Date: 2009.02.17
Time: 12:38:47
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 151668 km
Time Indication: 0
Date: 2009.02.17
Time: 12:38:47
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H44 0650
Coding: 0225115
Shop #: WSC 06435
2 Faults Found:
02261 - Media Player; Position 1 (R118)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 25
Reset counter: 137
Mileage: 149915 km
Time Indication: 0
Date: 2009.01.04
Time: 03:59:59
Freeze Frame:
Mileage: 151660 km
Count: 1602
Clock: 18:09
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 122
Mileage: 150720 km
Time Indication: 0
Date: 2009.01.31
Time: 14:16:25
Address 42: Door Elect, Driver Labels: None
Part No: 8P0 959 801
Component: Tuersteuerger. H10 0010
Coding: 0000120
Shop #: WSC 06435
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.9 1301
Address 46: Central Conv. Labels: 8P0-959-433.LBL
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 188800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.LBL
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Address 52: Door Elect, Pass. Labels: None
Part No: 8P0 959 802
Coding: 0000120
Shop #: WSC 06435
Address 55: Xenon Range Labels: 8P0-907-357.LBL
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000001
Shop #: WSC 06435
Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
Coding: 0225115
Shop #: WSC 06435
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 25
Reset counter: 137
Mileage: 149915 km
Time Indication: 0
Date: 2009.01.04
Time: 03:59:59
Freeze Frame:
Mileage: 151660 km
Count: 1602
Clock: 18:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 122
Mileage: 150720 km
Time Indication: 0
Date: 2009.01.31
Time: 14:16:25
Address 76: Park Assist Labels: None
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0000003
Shop #: WSC 06435
Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
E' laranja ou amarela a luz do motor ? tenho ideia q e' amarela.. a minha também acendeu, e era um sensor de temperatura de gases de escape se não estou em erro.
Quanto aos erros, não sou muito entendido nisso :\
Espero q nao seja nada grave.
SPIDER disse:
Obrigado,
Coding: 0000072
Shop #: WSC 00066
1 Fault Found:
P0401 - 000 - -
Freeze Frame:
RPM: 1323 /min
Torque: 92.0 Nm
Speed: 60.0 km/h
Load: 20.4 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
O problema da luz do motor é esse... e tem a seguinte "tradução":
16785/P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
Possible Symptoms
Drivebility problems (check dtc's with Knock Sensor)
Irregular behaviour
Possible Causes
EGR valve stuck closed
EGR valve leaks vacuum
EGR flow restricted
Circuit EGR short to B+
EGR damaged
Circuit DPF EGR sensor (differential pressure) disconnected, short to B+ or Ground
DPF EGR sensor downstream hose off or plugded
DPF EGR sensor damaged, wrong attached
Control Module damaged
Possible Solutions
Check all wiring and connections to and from EGR and DPF-EGR
Check the EGR: use a vacuumpump and pull open the EGR: rpm should change
Clean the EGR
Check / Replace EGR
Check / Replace DPF-EGR
Special Notes
The EGR system is monitored when driving at steady state and the EGR is commanded on. When the DPF-EGR sensor indicates that EGR flow is less then a desired minimum a dtc is set.
N.B. mechanics with less knowledge do exchange the EGR often, but 75% sure the problem will be back (probably the DPF-EGR sensor causes the problem).
Retrieved from "http://wiki.ross-tech.com/index.php/16785/P0401"
Tenta uma limpeza... pode ser que resulte.
8)
neljoe disse:
8)
sera k posso fazer eu isso, ou e melhor levar ao mecanico?
se sim, como?
obrigado
Problema:
Sera que nao fechas-te a EGR e nao a desactivaram electronicamente??
