KWP2000 não uma ferramenta muito boa, muito menos para um amador
tens razao. vou é tentar ver se ela deixa de entrar em saf mod... Ja lhe mudei a a N75 + continua na mesma. sem forças, em 5ª cm o pedal ao fundo n passa de 70 milhas... th estes erros.. Chassis Type: 7M - VW Sharan Scan: 01,02,03,08,09,15,16,17,18,19,29,36,37,39,45,46,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 019 FA Component: 1,9l R4 EDC G001SG 1269 Coding: 00002 Shop #: WSC 00021 3 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - -17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-00 - -17563 - Manifold Pressure Sensor (G71): Short to B+ P1155 - 35-00 - -Readiness: N/A
Address 03 ------------------------------------------------------- Controller: 1J0 907 379 P Component: ABS 20 IE CAN 0001 Coding: 12702 Shop #: WSC 00788 No fault code found.
Address 08 ------------------------------------------------------- Controller: 7M5 907 040 D Component: CLIMATRONIC MPV GP 0003 Coding: 00010 Shop #: WSC 00020 1 Fault Found: 00792 - A/C Pressure Switch (F129) 35-00 - -
Address 09 ------------------------------------------------------- Controller: 7M3 962 258 M Component: Multifunkt.Einh 0001 Coding: 04097 Shop #: WSC 00788 1 Fault Found: 01141 - Luggage Compartment Unlocking Switch (E165) 29-10 - Short to Ground - Intermittent
VAG-COM Self-Diagnosis Log Friday, 29 April 2016, 17:27:10 Page 2
VIN Number: License Plate:
Address 17 ------------------------------------------------------- Controller: 7M5 920 920 N Component: KOMBIINSTRUMENT VDO V30 Coding: 13421 Shop #: WSC 00788 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent
Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00020 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent
End ------------------------------------------------------
