Amigos em baixo deixo a minha lista de erros e se possivel uma ajudinha para resolver os mesmos.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 8E0 907 401 J
Component: 2.5l V6 TDI 0000SG 0005
Coding: 02005
Shop #: WSC 63251
00006059 130 106LC150_1.V79418803385
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04455
Shop #: WSC 00114
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63251
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63251
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01100
Shop #: WSC 00114
WAUZZZ8E64A031719 AUZ6Z0C0160499
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 07022
Shop #: WSC 63251
4 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
00956 - Key 2
Address 56 -------------------------------------------------------
Controller: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63251
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00858 - Connection: Radio ZF Output to Antenna Amplifier
29-10 - Short to Ground - Intermittent
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63251
End -------------------------------------------------------
Coding: 02005
Shop #: WSC 63251
1 Fault Found:
Readiness: N/A
Coding: 04455
Shop #: WSC 00114
Coding: 00000
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 63251
Coding: 00012
Shop #: WSC 63251
Coding: 01100
Shop #: WSC 00114
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
Coding: 07022
Shop #: WSC 63251
4 Faults Found:
35-00 - -
35-00 - -
00956 - Key 2
Coding: 01001
Shop #: WSC 63251
2 Faults Found:
Coding: 00114
Shop #: WSC 63251
