ola boas, tenho aqui uma lista de erros que mais parece uma lista de compras. alguem me podia ajudar com os erros?
obrigado
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 S
Component: 2.5l V6 TDI G000SG 0003
Coding: 07002
Shop #: WSC 00672
VCID: 356525E725C7
Part No: 00006059
Component: 130 106LC150_1.V79452687486
WAUZZZ8H45K006565 AUZ6Z0D0225587
3 Faults Found:
00560 - Exhaust Gas Recirculation System
08-10 - Control Limit Surpassed - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-10 - - - Intermittent
Readiness: 0 1 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04455
Shop #: WSC 99999
VCID: E5C535A755E7
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00100
Shop #: WSC 00672
VCID: 60CBA4B3CAC5
3 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 00000
VCID: 356525E725C7
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 D
Component: Airbag 8.4EC 0015
Coding: 0011104
Shop #: WSC 00672 785 00200
VCID: 3B7133DF03E3
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 P
Component: Lenksáulenmodul 0611
Coding: 04041
Shop #: WSC 00046
VCID: 408B44336A05
4 Faults Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
01303 - Telephone Transceiver (R36)
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 900 D
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00101
Shop #: WSC 00046
VCID: 285BFC93E275
4 Faults Found:
01316 - ABS Control Module
01334 - Door Control Module; Rear Right (J389)
01320 - Control Module for Climatronic (J255)
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6386
VCID: F3E15BFFEB33
1 Fault Found:
004 - No Signal/Communication - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: EFE9578F871B
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 F
Component: Komfortgerát T3B 3320
Coding: 00616
Shop #: WSC 00672
VCID: 37792FEF3FCB
Part No: 8H1959801C
Component: Tõrsteuer.FS BRM 3020
Part No: 8H1959802C
Component: Tõrsteuer.BF BRM 3020
Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
37-00 - Faulty
01560 - Passenger Door
61-10 - Won't De-Safe - Intermittent
80-10 - Single-Wire Operation - Intermittent
Address 56: Radio Labels: None
Part No: 8E0 035 186 N
Component: concert II GRO 0004
Coding: 13001
Shop #: WSC 00672
VCID: 326F1EFBD4A9
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
29-00 - Short to Ground
obrigado
Coding: 07002
Shop #: WSC 00672
VCID: 356525E725C7
Part No: 00006059
3 Faults Found:
Coding: 04455
Shop #: WSC 99999
VCID: E5C535A755E7
1 Fault Found:
00-00 - -
Coding: 00100
Shop #: WSC 00672
VCID: 60CBA4B3CAC5
3 Faults Found:
Coding: 00001
Shop #: WSC 00000
VCID: 356525E725C7
1 Fault Found:
Coding: 0011104
VCID: 3B7133DF03E3
Coding: 04041
Shop #: WSC 00046
VCID: 408B44336A05
4 Faults Found:
Coding: 00101
Shop #: WSC 00046
VCID: 285BFC93E275
4 Faults Found:
VCID: F3E15BFFEB33
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
VCID: EFE9578F871B
Coding: 00616
Shop #: WSC 00672
VCID: 37792FEF3FCB
Part No: 8H1959801C
Part No: 8H1959802C
Part No: 8H0959801A
Part No: 8H0959802A
6 Faults Found:
35-00 - -
35-00 - -
37-00 - Faulty
Coding: 13001
Shop #: WSC 00672
VCID: 326F1EFBD4A9
1 Fault Found:
