Boa tarde,
Alguem consegue arranjar um sistema de ligação da cabelagem dos faróis da b5 antigos para a versão restyling?
Isto porque as fichas são diferentes e precisava que alguém me desse uma luz de como proceder, ou seja, ligar
Já me deram esta ajuda:
Passenger Side
Tan/White (Low Beam) –Blue Wire (2)
Yellow/White (High Beam)-Yellow Wire (1)
Brown (Ground) –Black (4)
• Green Wire is for city light bulb in the head lamp T-Tap to parking lamp wire or cut and butt connect .
Drivers Side
White/Black (low Beam) – Blue Wire (2)
Yellow/Black (High Beam)-Yellow Wire (1)
Brown (Ground)-Black (4)
1. Remove corner lamp see Owners manual
2. Cut edge of the fender see picture
3. Disconnect Battery
4. Unplug Headlamp , roll back rubber boot and push metal clip down and pull back
5. Remove Headlamp (3) Torx Screw T-30 Two on top and one on the side
6. Remove Headlamp by sliding out toward corner area and the wiggle out
7. Look at plug locate purple triangular part move up. Slide off Plastic housing
8. There should be 4 wires 3 large and 1 small.
9. Slide Heat shrink over the 3 larger wires
10. Plug in wires according to chart above Slide Heat shrink over wire
**Before Shrinking plug on headlamp reconnect battery and check functions High low**
11. Next Shrink tubing using lighter, Slide over Bigger heat shrink to seal the three wires
12. Install Headlamp ,Install the headlamp pivot point into the hole , Insert two top torx screws
13. Plug Harness on headlamps
Mas fiquei um pouco confuso
Preciso mesmo de ajuda.
Obrigado a quem me puder ajudar.
Cumprimentos,
JorgeMMS
Passenger Side
Drivers Side
Cumprimentos,
JorgeMMS
