Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 019 CK
Component: 1,9l R4 EDC 0400SG 1243
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A047175 AUZ5Z0YN203113
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019970
Shop #: WSC 06435
2 Faults Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
012 - Electrical Fault in Circuit - Intermittent
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Component: A3 KLIMAAUT
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 00104
Shop #: WSC 06435
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 L
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 06140
Shop #: WSC 00058
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D14
Coding: 02049
Shop #: WSC 06435
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
End -------------------------------------------------------
A unica coisa que sei e que tenho um sensor do ESP avariado ou estragado, pk aparece no Quadrante a luz e nao apaga.. ja vi se tinha as luzes de stop todas boas , os encaixes todos e o break switch tudo esta bom..
O erro do radio tb sei qual e o mal dele.. e por nao fazer comunicação com o radio de origem.. agora no adress 08 .. tenho assim tantos erros que nem aparecem?
Coding: 00002
Shop #: WSC 06435
Coding: 0019970
Shop #: WSC 06435
2 Faults Found:
Coding: 00104
Shop #: WSC 06435
Coding: 06140
Shop #: WSC 00058
1 Fault Found:
01304 - Radio
Coding: 02049
Shop #: WSC 06435
3 Faults Found:
35-00 - -
28-00 - Short to B+
