[A3 8L] Audi A3 8l de Diogo_a3_180cv New wheels pag. 85
Re: Audi A3 8l de Diogo_a3_180cv (2 mods em estudo Possivel/impossivel)
Pessoal ontem a noite fui ligar o carro com VAG-COM para meter a trancar a porta as 20km/h e ja ta a bombar e aproveitei e fiz um scan e deu-me isto:
VCDS Version: Release 805.1
Data version: Versão -
Monday,26,October,2009,19:07:02:21461
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A112360 Mileage: 122110km/75875miles
Address 01: Engine Labels: 038-906-019-130.lbl
Part No: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1343
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A112360 AUZ7Z0A1838793
2 Faults Found
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435 000 00000
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 00104
Shop #: WSC 06435
1 Fault Found
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 931 J
Component: AB-KOMBIINSTR. VDO D12
Coding: 04140
Shop #: WSC 02120
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15211
Shop #: WSC 06435
5 Faults Found
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01374 - Shareware Version. To Decode all DTCs
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Shareware Version. To Decode all DTCs
09-00 - Please Register/Activate
Isto tradusido por miudos o que da?
Mais um problema isto chegame ao meio da barra do scan e depois nao passa dai devido a pedir licenças- :|
Segundo me parece tens ai uns problemazitos mas com certeza que ja passa por aqui pessoal a ajudar-te ;)
Se não notas nada deve ser erros antigos memorizados...apaga tudo e anda mais depois volta a ligar e ves ;) ;) ;)
boas
cm mudas-t as tuas lampadas nos bancos de tras?
cumps
koolboy disse:
Vou esperimentar faser isso. Mas eu tambem nao noto pode ser coisas que nao se nota assim de um pe para a mao. Mas vou esperimentar faser o que disseste.
Exkilo disse:
boas
cumps
Façil com uma chave de fendas pequena metes nos cantos do plafoier de tras e tiras aquilo completo e depois é so carregar a lampada para dentro rodar que ela desencaixa.
Se quiseres leds para ai tenho 4 para venda ;)
os led's ja tenho e a frente consegui tirar mas a tras nao deu :S
cumps
O erro do centr. locks. devem desaparecer tal como o erro no imobilizador...
Não houve uma vez que tu querias por o carro a trabalhar e ele pegava mas ia logo a baixo e a luz do imobilizador piscava?
King disse:
Nao isso nc me aconteçeu. :S
Diogo_a3_180cv disse:
Então é porque ainda foi antes de o comprares.. Mas se um dia te acontecer vai-te aparecer esse erro outra vez. E como esse é antes de o teres comprado então o do sensor da temperatura também deve desaparecer..
King disse:
Sim tenho de apagar os erros e andar uns dias para depois voltar a faser para ver no que da ;)
o ponteiro da temp tá sempre nos 90º ou varia?
King disse:
O ponteiro esta sempre nos 90. O carro ta todo normal nao noto qualquer diferença. Ta tudo a funcionar correctamente.
abraço
o erro da valvula do sensor de temp é muito comum.
prepara-te para queimar os dedos ao mudar :P
o erro do sensor do airbag tambem é normal e tambem ando a ver se o apago de vez.
não te preocupes, desde que o teu quadrante não pareça uma arvore de natal, deixa andar.
