Boas, liguei o meu argolas ao vag-com e apareceu-me a seguinte lista de erros. alguém me poderá especificar o que é ao certo e como resolve-los? obrigado
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0011266
Shop #: WSC 06435 000 00000
VCID: 2C57E2328CAB3A7E18B-5198
2 Faults Found:
01542 - Yaw Rate Sensor (G202)
012 - Electrical Fault in Circuit
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 00104
Shop #: WSC 06435
VCID: 4581B7965F01EB36E75-5198
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
VCID: 2C57E232DCAB3A7E18B-4F3E
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Coding: 0011266
2 Faults Found:
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
Coding: 14945
Shop #: WSC 06435
3 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
