[TABLE="class: carData, width: 100%"]
[TR="class: b1"]
[TD="width: 40%"]Brand[/TD]
[TD="width: 60%"]
Audi[/TD]
[/TR]
[TR="class: b0"]
[TD]Model[/TD]
[TD]
A4[/TD]
[/TR]
[TR="class: b1"]
[TD]Generation[/TD]
[TD]
A4 Avant (B5)[/TD]
[/TR]
[TR="class: b0"]
[TD]Engine[/TD]
[TD]
1.9 TDI (110 Hp)
[/TD]
[/TR]
[TR="class: b1"]
[TD]Doors[/TD]
[TD]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Power[/TD]
[TD]
110 hp
[/TD]
[/TR]
[TR="class: b1"]
[TD]Maximum speed[/TD]
[TD]
192 (190) km/h
[/TD]
[/TR]
[TR="class: b0"]
[TD]Acceleration from standstill to 100 km/h[/TD]
[TD]
11.5 (12.8) sec
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel tank volume[/TD]
[TD]
62 l
[/TD]
[/TR]
[TR="class: b0"]
[TD]Year of putting into production[/TD]
[TD]
1996 year
[/TD]
[/TR]
[TR="class: b1"]
[TD]Year of stopping production[/TD]
[TD]
2001 year
[/TD]
[/TR]
[TR="class: b0"]
[TD]Coupe type[/TD]
[TD]
Combi
[/TD]
[/TR]
[TR="class: b1"]
[TD]Seats[/TD]
[TD]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Length[/TD]
[TD]
4479 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Width[/TD]
[TD]
1733 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Height[/TD]
[TD]
1417 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Wheelbase[/TD]
[TD]
2622 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Front track[/TD]
[TD]
1498 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Rear (Back) track[/TD]
[TD]
1479 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Minimum volume of Luggage (trunk)[/TD]
[TD]
390 l
[/TD]
[/TR]
[TR="class: b1"]
[TD]Maximum amount of Luggage (trunk)[/TD]
[TD]
1250 l
[/TD]
[/TR]
[TR="class: b0"]
[TD]Model Engine[/TD]
[TD]
AFN
[/TD]
[/TR]
[TR="class: b1"]
[TD]Position of engine[/TD]
[TD]
Front, lengthwise
[/TD]
[/TR]
[TR="class: b0"]
[TD]Volume of engine[/TD]
[TD]
1896 cm[SUP]3[/SUP]
[/TD]
[/TR]
[TR="class: b1"]
[TD]Max power in[/TD]
[TD]
4150 rpm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Torque[/TD]
[TD]
235/1900 Nm
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel System[/TD]
[TD]
Diesel - Standard diesel injection (SDI)
[/TD]
[/TR]
[TR="class: b0"]
[TD]Turbine[/TD]
[TD]
Turbocharging (Supercharging)
[/TD]
[/TR]
[TR="class: b1"]
[TD]Valvetrain[/TD]
[TD]
OHC
[/TD]
[/TR]
[TR="class: b0"]
[TD]Position of cylinders[/TD]
[TD]
Inline
[/TD]
[/TR]
[TR="class: b1"]
[TD]Number of cylinders[/TD]
[TD]
4
[/TD]
[/TR]
[TR="class: b0"]
[TD]Diameter of cylinders (bore)[/TD]
[TD]
79.5 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Stroke in the cylinder[/TD]
[TD]
95.5 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Compression ratio[/TD]
[TD]
19.5
[/TD]
[/TR]
[TR="class: b1"]
[TD]Number of valves per cylinder[/TD]
[TD]
2
[/TD]
[/TR]
[TR="class: b0"]
[TD]Fuel Type[/TD]
[TD]
diesel
[/TD]
[/TR]
[TR="class: b1"]
[TD]Wheel Drive[/TD]
[TD]
Front
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Number of Gears (automatic transmission)[/TD]
[TD="width: 60%"]
4
[/TD]
[/TR]
[TR="class: b1"]
[TD]Number of Gears (manual transmission)[/TD]
[TD]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Front suspension[/TD]
[TD]
Several levers and rods
[/TD]
[/TR]
[TR="class: b1"]
[TD="width: 40%"]Rear suspension[/TD]
[TD="width: 60%"]
One-piece beam bridge
[/TD]
[/TR]
[TR="class: b0"]
[TD]Front brakes[/TD]
[TD]
Disc
[/TD]
[/TR]
[TR="class: b1"]
[TD]Rear brakes[/TD]
[TD]
Disc
[/TD]
[/TR]
[TR="class: b0"]
[TD]ABS[/TD]
[TD]
yes
[/TD]
[/TR]
[TR="class: b1"]
[TD="width: 40%"]Steering type[/TD]
[TD="width: 60%"]
Steering rack
[/TD]
[/TR]
[TR="class: b0"]
[TD]Power steering[/TD]
[TD]
Hydraulic Steering
[/TD]
[/TR]
[TR="class: b1"]
[TD]Minimum turning circle (turning diameter)[/TD]
[TD]
11.1 m
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Fuel consumption (economy) - urban[/TD]
[TD="width: 60%"]
6.9 (9) l/100 km.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel consumption (economy) - extra urban[/TD]
[TD]
4.3 (4.9) l/100 km.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Fuel consumption (economy) - combined[/TD]
[TD]
4.9 l/100 km.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Weight[/TD]
[TD]
1285 kg.
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Max weight[/TD]
[TD]
1835 kg.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Tire size[/TD]
[TD]
195/65 R15
[/TD]
[/TR]
[TR="class: b0"]
[TD]Wheel rims size[/TD]
[TD]
6J
[/TD]
[/TR]
[/TABLE]
