CONCERT I
http://www.ibiblio.org/tkan/audi/radios/concert.html
Concert
Audi part # 4B0 035 186
Audi part # 8N0 035 186 (USA only)
1998-1999 Audi A4, A6, A8 (Early 1998 A4 and A8 have Delta CC radio)
2000-2001 Audi TT
DIN standard size body with wide face plate
Single version, programmable for standard or Bose equalization
Cassette player with auto-reverse
AM/FM tuner, 6 AM presets, 12 FM presets, DX/Local, Seek/Scan
Controls for 6-disc CD changer (CD changer optional)
Random mode for CD
Bass, Treble, Balance, Fader
RDS/TPS (Radio Broadcast Data System/Type Search)
Dolby noise reduction
SVC (speed-sensitive volume compensation)
Navigation/Telephone mode auto volume attenuation
Anti-theft coding
Mode display in instrument cluster
Diagnostic-capable via OBDII port (via VAG-1552 or equivalent)
Made by Matsushita (Panasonic)
Programming Guide (Details about entering the anti-theft code and other programmable features)
The matching Audi OEM 6-disc CD changer (part # 4B0 035 111) is made by Matsushita and, of course, is plug-compatible without any modifications. The correct CD magazine for this changer is part # 3B0 051 179. The Concert radio can also be used with some aftermarket Panasonic CD changer models with an appropriate adapter and installation kit. For example, the Panasonic DP601, DP610, DP801 or DP810 changers are compatible. Look for them at Autotoys, Aamp of America, or your local car stereo specialist. There is also a 6-disc CD changer made by USA Spec that is also compatible, available from Crutchfields and other specialty car audio dealers.
The car comes pre-wired for a CD changer. The stock mounting location is in the trunk, in a plastic box (which is supplied with the installation kit) located to the left on the trunk floor.
This radio is compatible with the Audi PhatNoise digital audio player, see below.
