Auto-Scan não funciona
Boas, já andei apesquisar por aqui e não encontrei de relevante para mim. A ver se alguma alma caridosa me consegue ajudar.
Abaixo encontram-se os erros que tinha quando comprei o carro. Foi visto com o vag 12.12 de um amigo.
________________________________________________________________________
VIN: Wxxxxx1x11x111111 License Plate:
Mileage: 285820km-177600mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 200)
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: Wxxxxx1x11x111111 Mileage: 285820km/177600miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC 0000SG 1572
Coding: 00002
Shop #: WSC 63351
VCID: 72EDAA8A3ED84B8E9D9-4A9C
WAUZZZ8E93A237695 AUZ6Z0B0288466
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5C741D67F162C3688B-5000
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 264586DAC290672EC11-5072
2 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
VCID: 34616C92044C05BE4F5-4A9C
3 Faults Found:
79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3665569A423017AE711-5072
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
VCID: 3665569A123017AE711-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 00005
VCID: 2C5174F2DC7C5D7E175-5072
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AT
Component: Komfortgerát T23 1210
Coding: 06752
Shop #: WSC 00005
VCID: 83037F4E9162F20606F-4A3A
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
5 Faults Found:
00955 - Key 1
35-10 - - - Intermittent
01332 - Door Control Module; Passenger Side (J387)
53-10 - Supply Voltage Too Low - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01561 - Rear Left Door
61-00 - Won't De-Safe
01562 - Rear Right Door
61-10 - Won't De-Safe - Intermittent
Neste momento decidi comprar um só para não ter de andar sempre a pedir emprestado.
Quando tento o auto-scan, o mesmo dá-me erro de licença. Pelo que já estive a ver na net, poderia ter acontecido que eu tivesse ligado o pc à internet com o cabo do VAG introduzido na porta usb, e que o mesmo tivesse sofrido um upgrade firmware...o que faria com que ele não funcionasse mais. Mas acontece que isso não se passou, e eu consigo ver todos os módulos existentes no meu carro individualmente. Só o auto-scan não funciona.
Há alguém que saiba o porquê disto acontecer? Não é grave porque funciona tudo o resto. Já apaguei erros e tudo!!
Antes de mais começa por apagar todos os erros, mais tarde e após uns kilometros com o carro, volta a fazer scan..
Quanto ao auto scan, isso infelizmente é um erro em que aparece em alguns casos sem resolução, terás que fazer scan aos módulos individualmente..
Sim, já apaguei e voltei a fazer scan depois de 1000kms. A minha questão era só o erro do autoscan. Mas se não há nada a fazer não há stress. Obrigado pela resposta.
Enviado do meu FIG-LX1 através do Tapatalk
Não faz autoscan por que esse vagcom tá marado.. como não tem licença válida, não dá para autoscan nem te irá deixar codificar alguns modulos se precisares..
Ou seja, reclama o cabo e pede outro.
Fosgasse, mas porque é que tu não vendes cabos? Eheheh
Na primeira foto diz que a licença está válida. Ou não é ali que se vê?
Eu só quero ver erros e apagar. Para alterações deixo para ti e mais ninguém [emoji16][emoji106]
uiiii o Teixeira de cabo VAG :D essa merda vai dar raia cáraaaaa :p
faz como eu... usas um PC portátil velho velhinho que é lixo... instalas o XP, o meu nem wireless tem lol o VAG nunca falha :p pode é não fazer algumas coisas!
Isso infelizmente acontece em muitas versões...
As ultimas versões ou pouco fazem ou não fazem tudo (não entram em calibração de G85 / ABS), ou dão este erro da licença e depois desaparece se reiniciar o computador ou não fazem diagnostico de modulos por L-Line....enfim,...
Saudades das versões 607, 70* e 908....
uiiii o Teixeira de cabo VAG :D essa merda vai dar raia cáraaaaa [emoji14]
faz como eu... usas um PC portátil velho velhinho que é lixo... instalas o XP, o meu nem wireless tem lol o VAG nunca falha [emoji14] pode é não fazer algumas coisas!
Eu até prefiro que não faça nada!! Ao menos não corro risco[emoji23][emoji23][emoji23]
Não fazia ideia de que tinha a ver com as versões mais recentes. Vou experimentar fazer restart e ver a licença durante o autoscan.
Quando ele der esse erro do autscan vai novamente ver a licença
Pois é, já experimentei ver a licença, e a mesma continua válida depois do erro mister @jimy :assobio::D
Quando dá o erro eu não consigo ir ao "about" para ver a licença. Então tenho de fechar o erro. Depois de o fechar também não consigo ir ao "about" porque ainda estou dentro do módulo....só depois de sair do módulo é que consigo ir ao "about" e quando lá vou está tudo bem.
Mas é estranho porque ele faz o autoscan um bocadinho e depois falha mas não é sempre no mesmo módulo.
Normalmente ele começa a fazer o autoscan no engine e depois ao abs (tipicamente dá o erro depois do abs). Ontem estive a fazer e correu mais uns módulos e deu o erro mais abaixo.
Ontem leu estes:
Address 01: Engine
Address 15: Airbags
!!erro!!
Deve ser mesmo o que o @ELFuracon diz....estas modernices não servem para nada a não ser para ler erros :p:D:D:D
já experimentei cabos desses 15.7 e 18.2, e incrivelmente o que funciona em condições é o 908 não falha nada mesmo com o sw mais recente, o 15.7 não deixa gravar no módulo ABS nem entra no rádio por exemplo.. o 18.2 faz autoscan mas só no HVAC :P
O meu cabo é o vag182 e o sw é o 18 qualquer coisa. Pois, o meu começa por fazer o autoscan mas inevitávelmente acaba por dar erro. Às vezes mais à frente outras vezes mais atrás.
