Aqui fica o pinout dos dois módulos das poirtas da frente (condutor/passageiro)
Connectors, door control unit, driver side -J386
20-pin connector (supply, lock)
1 - Mirror dip input signal 1 (EC mirror +)
2 - CL motor SAFE
3 - CL feedback locked/safe
4 - CL outside door handle
5- Vacant
6- Vacant
7 - CL terminal 31
8 - CAN - High
9 - CAN - Low
10 - Mirror dip input signal 2 (EC mirror -)
11 - CL motor SAFE/lock
12 - CL terminal 30
13 - CL keyswitch close/open
14- Vacant
15 - CL door contact switch
16 - CL motor unlock
17- Vacant
18 - WL enable, terminal 87 (vacant)
19 - WL terminal 31
20 - WL terminal 30
16-pin connector (exterior mirrors)
1 - Mirror status position X (only with seat memory fitted)
2 - Mirror terminal 31, potentiometer (only with seat memory fitted)
3 - Mirror supply, potentiometer (only with seat memory fitted)
4 - Mirror adjustment motor Y-direction
5 - Mirror adjustment motor X/Y-direction
6- Vacant
7 - Mirror heating
8 - Mirror dip output signal 1 (EC mirror +)
9 - Mirror status position Y (only with seat memory fitted)
10- Vacant
11 - Mirror terminal 31
12 - Mirror adjustment motor X-direction
13- Vacant
14 - Mirror folding motor -
15 - Mirror folding motor +
16 - Mirror dip output signal 2 (EC mirror -)
32-pin connector (to door trim)
1 - BE - Exit/warning lamp
2 - BE - Terminal 31 (2) (AWL)
3 - BF - Window lifter button rear right
4 - BE - Terminal 31 (1) (AWL)
5 - CL SAFE LED
6 - BE - Terminal 58b (1)
7 - BF - Interior locking button (LOCK/UNLOCK)
8 - BF - Window lifter button front right (local)
9- Vacant
10 - Memory button + emergency off button (only with seat memory fitted)
11 - Memory position buttons (only with seat memory fitted)
12 - BF - Tailgate remote release button (only in 5-door, USA)
13 - Alarm system Off button (tilt sensor inactive)
14 - BE - Interior door handle illumination
15- Vacant
16 - Status LED button for interior monitoring (deactivate interior monitoring)
17 - Status LED button for alarm system off (deactivate tilt sensor)
18 - CL - Inside door handle (not implemented)
19 - BF - Mirror adjustment L/R
20 - BF - Mirror adjustment X/Y
21 - BF - Window lifter button rear right (local)
22 - BE - Terminal 58b (2) (mirror adjuster switch)
23 - BE - Terminal 58b (3) (mirror/stowage illumination)
24 - BF - Window lifter button front left (local)
25- Vacant
26 - BF - Child lock
27 - Memory supply terminal 30
28 - BF - Button for tank lid unlock
29 - BF - Mirror heating
30 - Button for interior monitoring
31 - LED - Interior locking button (LOCK)
32 - LED - Child lock button
Connectors, door control unit, front passenger side -J387
2 - Central locking (CL) motor SAFE
5- Vacant
6- Vacant
7 - CL terminal 31
8 - CAN - High
9 - CAN - Low
12 - CL terminal 30
14- Vacant
17- Vacant
18 - Window lifter (WL) enable, terminal 87 (vacant)
19 - WL terminal 31
20 - WL terminal 30
6- Vacant
7 - Mirror heating
10- Vacant
13- Vacant
3- Vacant
5- Vacant
9- Vacant
10- Vacant
11- Vacant
12- Vacant
13- Vacant
15- Vacant
16- Vacant
17- Vacant
19- Vacant
20- Vacant
21- Vacant
22 - Vacant
24- Vacant
25- Vacant
26- Vacant
27- Vacant
28- Vacant
29- Vacant
30- Vacant
32- Vacant
Tirado de: audi-portal.com
