:roll:
4.12 Can I use VAG-COM to retrieve my Radio Code to get it out of "SAFE" mode?
No, You'll need to get the radio code from your dealer (it should also be on a card that came with your car). Most likely, the dealer will need to physically remove the radio to read its chassis number, then the chassis number is input into a database at the dealership to retrieve the radio code. Neither VAG-COM nor the factory scan tools can retrieve the radio code for you.
:roll:
Se tivesses o código:
"Using station preset buttons #1 (for first digit) thru #4 (for fourth digit, enter your radio code, then press and hold FM2 and RDS untill display says "SAFE", and then release."
Basicamente, utilizas as teclas 1 até 4 das emissoras para colocares o código certo... depois é FM2 e RDS juntos até aparecer SAFE.
:wink:
