Boas a todos,
Tenho o mesmo problema do "trinita"
Aqui vai o scan completo:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 JT
Component: 1,9l R4 EDC 0000SG 1572
Coding: 00002
2 Faults Found:
Shop #: WSC 63351
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
5 Faults Found:
00797 - Sunlight Photo Sensor (G107)
31-10 - Open or Short to Ground - Intermittent
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
7 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
01326 - Control Module for Multi-Function Steering Wheel (J453)
79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
52-10 - Supply Voltage Too High - Intermittent
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
01334 - Door Control Module: Rear Right (J398)
01331 - Door Control Module: Driver Side (J386)
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00100
Shop #: WSC 00066
WAUZZZ8E03A204262 AUZ6Z0B0301863
2 Faults Found:
00668 - Supply Voltage Terminal 30
01304 - Radio
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 06730
Shop #: WSC 63351
19 Faults Found:
37-00 - Faulty
01320 - Control Module for Climatronic (J255)
01134 - Alarm Horn (H12)
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
00956 - Key 2
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01560 - Passenger Door
61-00 - Won't De-Safe
01332 - Door Control Module: Passenger Side (J387)
01561 - Left Rear Door
01333 - Door Control Module: Rear Left (J388)
01562 - Right Rear Door
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63351
4 Faults Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
00856 - Radio Antenna
00858 - Connection: Radio ZF Output to Antenna Amplifier
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00104
Shop #: WSC 63351
1 Fault Found:
00625 - Vehicle Speed Signal
End -------------------------------------------------------
Atenciosamente
Rui Louzado
