Dúvida nas molas e amortecedores A3 8P
Pelo o que estive a ver, na familia dos códigos Gxx relativos a suspensao, o unico que se refere a suspensao desportiva é o G81.
Os outros nao fazem mais referencia pelo que talvez sejam standard.
No meu A4 os codigos pra suspensao comecam por 1Bx.. Sendo que o meu é 1BA (standard).
Mas o teu nao tem nenhum codigo comecado por 1Bx..
Exactamente. Eu tenho o catálogo dos códigos. Vê se consegues ver por este site. Descarrega o ficheiro em PDF. https://www.google.pt/url?sa=t&sour...FjAFegQIDhAC&usg=AOvVaw3kh7P4LVKBw4co4eVS6wDw
Tirei da net o significado dos teus codigos:
PRCode: 0YF = Weight range 6 installation control only no requirement forecast
PRCode: 1AT = Electronic stabilization program (ESP)
PRCode: 1KD = Disc brakes rear
PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
PRCode: 1SA = Without additional engine guard
PRCode: 1ZE = Disc brakes front (Geomet D)
PRCode: 2FQ = Leather trimmed multi-function sports steering wheel w/ Tiptronic
PRCode: 3FE = Electric slide/tilt sunroof with sun screen/sunblind
PRCode: 3L3 = Manual height adjustment for front seats
PRCode: 3NU = Rear seat bench unsplit backrest split folding with center armrest
PRCode: 3Y6 = Sun screen for rear window
PRCode: 4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
PRCode: 4K4 = Radio remote controlled central locking
PRCode: 4KC = Side and rear windows in heat-insulatingglass
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 4X3 = Side air bag front with curtain air bag
PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
PRCode: 5RU = Right exterior mirror: convex (large viewing field)
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 5TG = Decorative aluminum inserts dulling
PRCode: 6XD = Exterior mirrors: electrically adjustable/heated
PRCode: 7A0 = Without CD changer/CD player
PRCode: 7GG = Emission standard EU4 DPF
PRCode: 7K6 = Flat tire indicator
PRCode: 7Q9 = Navigation system
PRCode: 7X1 = Park distance control
PRCode: 8BB = Halogen headlight for driving on the right
PRCode: 8GU = Alternator 140 A
PRCode: 8Q1 = Headlight-range adjustment
PRCode: 8Z5 = Not hot country
PRCode: 9Q2 = Multi-function display/on-board computerwith check control
PRCode: CD7 = Alloy wheels 7.5J x 17
PRCode: D7N = 4-cyl. turbo diesel engine 2.0 L/103 kW TDI with pump-jet injection system base engine is TM0/TP0/TR0
PRCode: E4J = S-line
PRCode: F0A = No special purpose vehicle standard equipment
PRCode: G34 = Front shock absorption
PRCode: J1D = Battery 380 A (72 Ah)
PRCode: L85 = Suspension range 85 installation control only no requirement forecast
PRCode: TM0 = 4-cylinder diesel engine 2.0 L unit 03G.7
PRCode: U2A = Instrument insert with km/h speedometer radio-controlled clock tachometer and trip odometer
PRCode: UA3 = Rear shock absorption
PRCode: UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
PRCode: X0A = National sales program Germany
Eu acho que o teu carro tem o equipamento standard, porém terá um interior s-line.
Obrigado pela tua disponibilidade a ver isso. Então sendo assim que amortecedores (referência) meto em conjunto com as eibach pro kit? As eibach basta pedir para o modelo 8P1 certo?
Isso agora depende...
Eu penso que as pro kit adequam-se a suspensao normal.. As sportline já não, ai vais precisar de amortecedores mais rijos.
Mas fala com o @madlima29 , ele colocou Sachs no 8P dele..
Pois eu tenho acompanhado o projeto dele... Ele é que me falou salvo erro em meter Sachs. Agora resta saber se meto espigão curto ou normal
A Mao de obra é minha portanto 500€ é o valor das molas e amortecedores? Sei que as molas ficam à volta dos 200€
Mão de obra é tua? Tens prensa para as molas? Pela net encontras as pro kit por volta dos 150 euros.. 350 pra amortecedores, foles, chega bem.
Agora se ao desmontares vires que os cabeçotes estão maus, muda-os também.
Sim tenho prensa amigo. E elevador no trabalho para fazer o serviço como deve ser.
