Erro 17911 e 01316-ABS control módulo
Alguém sabe o que significa os seguintes erros no VAG COM
O carro já foi a um electricista e o tipo disse que o carro tinha a centralina lixada :?: :?: :?:
Será :?: :?:
Parece mais o módulo do ABS :?: :?:
Se mudar o módulo do ABS resolve?
Os sintomas do carro é estar cada passo a acender o luz do control de tracção.
É estranho o erro no 17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent o que terá haver um erro com o outro :?: :?:
Obg
VAG-COM Version: Release 704.1
Sunday,10,February,2008,12:43:54:55371
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 143460km/89141miles
Address 01: Engine Labels: 038-906-019-115.LBL
Part No: 038 906 019 CJ
Component: 1,9l R4 EDC 0000SG 1045
Coding: 00002
Shop #: WSC 01317
1 Fault Found:
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 01317
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 01317
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 01317
Address 17: Instruments Labels: 1J0-920-xxx-17.LBL
Part No: 1J0 920 822 C
Component: A4-KOMBIINSTR. VDO V25
Coding: 05144
Shop #: WSC 54321
Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2327880
IMMO-IDENTNR: VWZ7Z0Y2327880
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in ABS Control Module
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal Possible Causes
Alternator faulty
Voltage Regulator faulty
Wiring and/or connections faulty
Possible Solutions
Check / Replace Alternator
Check / Replace Voltage Regulator
Check wiring and connections
Check the fuse box that is in the battery tray, it might be burnt, the fuse or the complete plastic box (pretty common failure on Sharan because it carries so much electrical load). If so, change the complete fuse box, it is not too expensive fix if this is the cause.
Engº. Artur disse:
Possible Causes
Possible Solutions
Alternator faulty
Possible Solutions
Obrigado Artur
Viste isto onde?
Quando quiser, passe no Funchalinho ou ligue-me para o telele que eu vejo-lhe isso.... Isso é efectivamente o módulo ABS que foi à vida. A questao é saber qual o erro...
