Boa tarde,
Sou inexperiente neste assunto, o meu A4 B8, em andamento acendeu brevemente a luz de resistência e depois ficou acesa a luz de avaria de motor. Fiz o scan e recebi isto, algo grave?
1 Fault Found:
5296 - Throttle Valve Actuator Module (J338): Motor Circuit
P2102 00 [168] - Signal Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 86
Mileage: 181905 km
Date: 2016.09.21
Time: 09:16:33
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 P HW: 8K0 907 379 P
Component: ESP8 front H04 0180
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 02399 823 56573
VCID: 4683B093F152362EEEF-8013
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 180981 km
Time Indication: 0
Date: 2016.09.03
Time: 13:10:52
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x00A6
Hex Value: 0x1F21
Hex Value: 0x1696
Hex Value: 0x00FF
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
Component: GW-BEM 5CAN H04 0084
Revision: GA801030 Serial number: 3000G081038142
Coding: 000003
Shop #: WSC 84200 261 65321
VCID: 428BAC83DD7A0A0EC27-8017
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
1 Fault Found:
03041 - Energy Management Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 31
Reset counter: 242
Mileage: 174998 km
Time Indication: 0
Date: 2016.04.14
Time: 15:26:52
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 16
Reset counter: 118
Mileage: 174582 km
Time Indication: 0
Date: 2016.04.06
Time: 10:57:27
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 131
Mileage: 174582 km
Time Indication: 0
Date: 2016.04.06
Time: 15:40:22
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 86
Mileage: 181905 km
Date: 2016.09.21
Time: 09:16:33
Coding: 160500
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 180981 km
Time Indication: 0
Date: 2016.09.03
Time: 13:10:52
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x00A6
Hex Value: 0x1F21
Hex Value: 0x1696
Hex Value: 0x00FF
Coding: 000003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Reset counter: 242
Mileage: 174998 km
Time Indication: 0
Date: 2016.04.14
Time: 15:26:52
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 118
Mileage: 174582 km
Time Indication: 0
Date: 2016.04.06
Time: 10:57:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 131
Mileage: 174582 km
Time Indication: 0
Date: 2016.04.06
Time: 15:40:22
