erros???? desifrar... ...
boas,
hoje liguei o vag-com ao meu carro e apareceu-me estes erros:
19561; 17957; 17849; 18058; 17978
alguem me sabe desifralos?? é k ñ sei o k significam :S
ajuda sff
cumps
17957/P1549/005449 - Boost Pressure Controle Valve (N75): Open Circuit / Short to Ground
[edit]Possible Symptoms
Irregular behaviour
Loss of power
Limp mode
[edit]Possible Causes
Wiring and/or connections faulty (short circuit)
N75 faulty
[edit]Possible Solutions
Check wiring and connections
Check / Replace N75
Retrieved from "http://wiki.ross-tech.com/index.php/17957/P1549/005449"
Categories: Fault Codes
17978/P1570 - Engine Start Blocked by Immobilizer
Engine starting but stalling immediately
Key(s) not matched
Instrument Cluster not matched
Engine Control Unit (ECU) not matched
Engine Control Unit (ECU) Power Supply faulty
Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
Check Engine Control Unit (ECU) Power Supply (Relay)
[edit]Special Notes
If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
17849 nao encontrei
18058 nao encontrei
19561 Possible Symptoms
Engines shakes at shutdown
Wiring Open Circuit or Short to Ground
Valve for Intake Manifold Flap (N239) faulty
Check Wiring for Open Circuit or Short to Ground
Check Valve for Intake Manifold Flap (N239) > Output Test
o carro faz safe mode???
Verifica a geometria do turbo, antes de mexeres na n75.
Ja agora verifica tb os tubos do vacuo.
Abraço e diz algo
Bruno Oliveira disse:
Abraço e diz algo
já verifikei... o meu mecanico diz tar tudo ok... ñ entendo... :sad:
