erros no vag,e leitura de kilometros certa!! :)
liguei o carro ao vag e para minha felicidade,deu certo os kilometros,com uma diferença de 60 + ou -
agora o que pedia aos mais intendidos era se me podiao ajudar na leitura dos erros que aparecerao.agradeço a ajuda que puderem dar.
cumprimentos
VIN: XXXXXXXXXXXXXXXXX Mileage: 198970km/123634miles
Part No: 038 906 012 AH
Component: 1,9l R4 EDC 0000SG 2705
Coding: 00002
Shop #: WSC 06335
VCID: 56A89ADC9881
3 Faults Found:
17969 - Quantity Adjuster (N146): Control Deviation
P1561 - 35-10 - - - Intermittent
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB882FCF0B1
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D56
Coding: 00043
Shop #: WSC 06335
VCID: 2A501E2CFC79
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 0001
Coding: 00104
Shop #: WSC 06335
VCID: 3D7A25701DF7
2 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 932 FX
Component: B5-KOMBIINSTR. VDO D13
Coding: 00140
Shop #: WSC 54321
VCID: 830E1388BB93
XXXXXXXXXXXXXXXXX AUZ7Z0C2319013
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 13131
Shop #: WSC 00000
VCID: EAD05E2CBCF9
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
Breack switch deves trocar. Verifica a relé de alimentação.
O erro de airbag é mau contacto nas fichas.
Tens uma pequena fuga de ar no fecho central.
Os kilometros, se foi bem martelado, mesmo que bata certo no vag, não é garantia.
Os kilometros, se foi bem martelado, mesmo que bata certo no vag, não é garantia.[/QUOT
sabes me dizer se sao peças muito caras?a rele de alimentaçao tem a ver com o brake switch?um dia acendeu me a resistencia em andamento e quando toquei no pedal de travao desapareceu....tera alguma coisa a ver?
obrigado pela ajuda
se ten a luz de airbag apagada, esses erros sao antigos, tal como ja te respondi acima no outro topico, apaga todos os erros e volta a ligar ao VAG daqui a uns dias..
x2.
Acho que o melhor procedimento a tomar sempre, é gravar um log dos erros, apagar e ver de novo passado uns dias.
cumprimentos
Coding: 00002
Shop #: WSC 06335
VCID: 56A89ADC9881
3 Faults Found:
P1601 - 35-00 - -
P0571 - 35-00 - -
Readiness: N/A
Shop #: BB 24548
VCID: 5EB882FCF0B1
Coding: 00043
Shop #: WSC 06335
VCID: 2A501E2CFC79
Coding: 00104
Shop #: WSC 06335
VCID: 3D7A25701DF7
2 Faults Found:
Coding: 00140
Shop #: WSC 54321
VCID: 830E1388BB93
Coding: 13131
Shop #: WSC 00000
VCID: EAD05E2CBCF9
2 Faults Found:
35-00 - -
35-00 - -
queres que meta a tua centralina com 300.000 ou 100.000? esqueçe o vag..... boa sorte com o carro ;) faz revisões... mete gasoleo :D
