Erros no vagcom
Na quinta feira de manha quando fui a colocar o carro a trabalhar, após ele pegar acendeu a luz do ESP.Desliguei voltei a ligar e a luz desligou não voltando mais a acender e a estar tudo normal.Hoje liguei ao vagcom e deu-me estes erros:
VCDS Version: Beta 812.4
Data version: 20090214
Sunday,15,July,2012,10:09:46:26365
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A006111 Mileage: 183290km/113891miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1243
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A006111 AUZ7Z0Y1535278
1 Fault Found
16705 - Engine Speed Sensor (G28 ): Implausible Signal
P0321 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 06435
1 Fault Found
00812 - Brake Pressure Release Solenoid (F84)
Será que algum erro está relacionado com a ligação da luz do ESP?já sei que me vão perguntar se o brake switch está a funcionar bem e eu digo que sim:)
se algum deles estiver relacionado, é o 2º erro ;)
Tive a pesquisar e está relacionado com o 1º:
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28 ) loose
Engine Speed Sensor (G28 ) faulty
Possible Solutions
Check Engine Speed Sensor (G28 )
Special Notes
The Engine Speed Sensor (G28 ) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
When an engine will not start due to mechanical timing or spark/fuel related issues it is not uncommon to set G28/G40/G163 fault codes. The basics should be checked if this code returns after extended craning and a no-start with a new sensor installed.
When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro magnetic interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
Bem como o carro pega mal, lá vai ter de levar o sensor novo:S
mas olha que no primeiro não vem nada a referenciar o ESP :S
ja no 2º vem...
ora ve o que esta na primeira linha sublinhado a vermelho
Coding: 18945
Shop #: WSC 06435
1 Fault Found
Mas quando dá muita resistencia a pegar acende sempre a luz do ESP;)
Apaguei os erros e amanha ao fim do dia vou voltar a ligar a ver se aparece,pois nunca mais voltou a acontecer pegar daquela forma;)
Bem voltou a aparecer a luz o ESP ligo ao vagcom e aparece-me novamente este erro:
alguém com o ETKA sabe o valor dele e onde está situado num A3 8L?:S:S
Esta penso eu que junto a correia da distribuição.
procura junto ao filtro de oleo, nos A4 B5 situa-se ai..
[/IMG]
