tenho a carrinha a pouco tempo e arranjaram m um cabo vag com para a ligar um pouco rudimentar mas para o k e chega por agora...o cabo e o kkl vag-com para o 409.1(como n consegui resgistrar o programa tive k usar o 311.2) e deu m estes erros:
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Controller: 038 906 019 GF
Component: 1,9l R4 EDC G000SG 1541
Coding: 00002
Shop #: WSC 02325
WAUZZZ4B12N132314 AUZ7Z0B2093636
No fault code found.
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06255
Shop #: WSC 00000
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
Address 17 -------------------------------------------------------
Controller: 4B0 920 933 G
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 00040
Shop #: WSC 00222
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06987
Shop #: WSC 02325
9 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
Address 37 -------------------------------------------------------
Controller: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0140
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
36-00 - Open Circuit
Address 56 -------------------------------------------------------
Controller:
End -------------------------------------------------------
pelo k percebi a carrinha ja teve uma batida( 01366 - Opened Due to Crash Signal
35-00 - -)os outros e k nao percebo...
alguem me pode ajudar???
amanha vou apagar os erros e ver o k da de novo....
cumprimentos
Coding: 00002
Shop #: WSC 02325
Coding: 06255
Shop #: WSC 00000
Coding: 01002
Shop #: WSC 02325
Coding: 00040
Shop #: WSC 00222
Coding: 06987
Shop #: WSC 02325
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
1 Fault Found:
Controller:
cumprimentos
