Boas.
Tenho um Seat Leon 1P de 2008.
Até a data 0 problemas. Ontem deixou de abrir a porta do passageiro com comando e chave.
E tambem começou a pegar mal. Ou seja demora mais que o costume. Liguei VAG COM deu estes erros. Que podera ser ?
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H08--- Serial number: SEX7Z0H431F05H
Coding: 0050071
Shop #: WSC 06441 785 00200
1 Fault Found
000833 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 18
Mileage: 176873 km
Time Indication: 0
Date: 2000.00.00
Time: 00:40:14
Freeze Frame:
RPM: 819 /min
Speed: 27.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101111
Idle Stabilization: 0.0°KW
(no units): 48.0
Readiness: 0 0 0 0 0
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006850560084F01207C80
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found
01038 - Central Locking Thermal Protection
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 130
Reset counter: 61
Mileage: 176871 km
Time Indication: 0
Date: 2000.00.00
Time: 23:08:49
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1129
Revision: 31008001 Serial number: 00000064388310
Coding: 0000176
2 Faults Found
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 97
Reset counter: 61
Mileage: 176667 km
Time Indication: 0
Coding: 0050071
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Mileage: 176873 km
Time Indication: 0
Date: 2000.00.00
Time: 00:40:14
Freeze Frame:
RPM: 819 /min
Speed: 27.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101111
(no units): 48.0
1 Fault Found
Freeze Frame:
Fault Priority: 4
Reset counter: 61
Mileage: 176871 km
Time Indication: 0
Date: 2000.00.00
Time: 23:08:49
Coding: 0000176
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 97
Reset counter: 61
Mileage: 176667 km
Time Indication: 0
