Erros vag-com
Poderiam me ajudar a desvendar esses erros do meu 8l ?
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 06A 906 018 CJ
Component: 1.8L R4/5VT MOTR HS D01
Coding: 04000
Shop #: WSC 00000
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 K
Component: A3 KLIMAAUT
Coding: 00040
Shop #: WSC 00000
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 M
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 00544
Shop #: WSC 00113
XXXXXXXXXXXXXXXXX AUZ7Z0E2716719
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D16
Coding: 14188
Shop #: WSC 00137
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
End -------------------------------------------------------
Limpa e faz novo scan.
O teu klimatronic deve dar erros novamente e só depois de limpar é que se vai ver o quê.
