Erros vagcom 311 - opinião dos entendidos sff?
Boas malta, tenho duas opiniões a pedir sobre dois carros aqui dos meus amigos
1º carro AH-celso:
Chassis Type: 8L - Audi A3/S3\par
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56\par
\par
Address 01 -------------------------------------------------------\par
Controller: 038 906 012 A \par
Component: 1,9l R4 EDC 0000SG 2801\par
Coding: 00002\par
Shop #: WSC 06435\par
1 Fault Found:\par
18062 - Please check DTC Memory of Instrument Cluster\par
P1654 - 35-10 - - - Intermittent\par
Readiness: N/A\par
\par
Address 03 -------------------------------------------------------\par
Controller: 1J0 907 379 Q \par
Component: ABS/EDS 20 IE CAN 0001\par
Coding: 13304\par
No fault code found.\par
\par
Address 08 -------------------------------------------------------\par
Controller: 8L0 820 043 M \par
Component: A3 KLIMAVOLLAUTOMAT_D77\par
Note: Excessive Comm Errors\par
\par
Skipping Address 15-Airbags\par
\par
Address 17 -------------------------------------------------------\par
Controller: 8L0 920 900 B \par
Component: KOMBI+WEGFAHRS. M73 D14\par
Coding: 00140\par
Shop #: WSC 00000\par
Ident.-Nr. Wegfahrs.:AUZ5Z0Y0283081\par
1 Fault Found:\par
01039 - Coolant Temperature Sensor (G2)\par
30-10 - Open or Short to B+ - Intermittent\par
\par
Address 35 -------------------------------------------------------\par
Controller: 8L0 862 257 K \par
Component: ZV-Pumpe, Funk D11\par
Coding: 12896\par
2 Faults Found:\par
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)\par
35-00 - -\par
00955 - Key 1\par
09-00 - Adaptation Limit Surpassed\par
\par
End -------------------------------------------------------\par
Opinião :?:
2º carro AT - Miguel (1275gt):
Controller: 038 906 012 BB
Component: 1,9l R4 EDC 0400SG 2809
Coding: 00002
Shop #: WSC 00049
Controller: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 06435
Controller: 8L0 920 930
Component: KOMBI+WEGFAHRS. M73 D16
Coding: 00040
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0Y6133098
Coding: 14944
Shop #: WSC 06435
2 Faults Found:
35-00 - -
00956 - Key 2
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 D
Component: Radio 0001
Coding: 00017
Shop #: WSC 06435
Opinião :?:
desculpem pelo tamanho do tópico mas foi o resultado do vagcom e para não fazer dois tópicos diferentes!
cumps
Ah estes dois grandes malucos deixaram aqui o pro mexer naquilo pela primeira vez. sujeitos a ficar sem carroça os malucos :p
O erro do sensor G2 quer dizer que a vavula de temperatura está nos cascos. è preciso substituir a dita :wink:
rmatos disse:
Então o ponteiro da temperatura estar a dar valores malucos pode ser daí? esqueci.me de referir os sintomas dos carros, mas estava a ver se adivinhavam pelos erros :p
ProBoarder disse:
rmatos disse:
Foi o que me aconteceu á minha viatura :wink:
Thx ele queixa-se disso. o segundo as vezes faz a mesma cena mas não deu erro! deve ser do quadrante né? pk ele diz que dá um tokezinho naquilo "MURRO" lol e fica melhor.
O erro da bomba das portas é normal...basta abrir o motor de vacuo e limpar k desparece.... mas tb n faz difrença nenhuma.
O erro do G2 ja foi explicado...
Um deles tem ali uma chave k foi recodificada vezes de mais sem fazer o reset.
O erro de DTC.... epa devem ter mudado o quadrante ao carro ja :shock:
