erros vagcom
bOas, recebi o vagcom e fui esprimentar fazer um scan
Deu´me isto tudo...alguem sabe dizer o que significa?
de salientar que ando com um problema de travoes que quando travo faz uma vibraçao enorme e nao é discos empenados.
des de ja agradeço atençao ;)
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P84A022649
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5184
Revision: 12345678 Serial number: AUX7Z0C4FNS0AC
Coding: 0000072
Shop #: WSC 06435 000 00000
3 Faults Found
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Temperature: 63.0°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Torque: 220.0 Nm
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1260 /min
Torque: 50.0 Nm
Speed: 19.0 km/h
Load: 20.0 %
Duty Cycle: 14.7 %
Bin. Bits: 00000000
Mass Air / Rev.: 300.0 mg/str
Mass Air / Rev.: 490.0 mg/str
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0120
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006536822
Coding: 01884F0082141000000000000000000000
Part No: 8P1 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
Saturday,18,April,2009,00:01:30:21461
VCDS Version: Release 805.1
Data version: 20080823
Mestre rafael disse:
tens um problema na egr
e na ventuinha de arrefecimento
haaa, a egr foi por ter posto supressor...e como neste carro parece que nao da para tirar o erro :S
agora ventoinha de arrefecimento, podes dizer mais precisamente o que é isso e se é caro e grave!?
E tem mais alguma coisa que nao conseguiste disifrar ou toda aquela informaçao e apenas destes dois erros??
muito obrigado...
cumprimentos mestre ;)
17075=motor da ventoinha do liquido de arrefecimento ou seja tens um problema na primeira ventoinha ou na primeira velocidade da mesma
19558=actuador do controlo do ar do colector de admiçao ou seja ou esta marada ou tem mau contacto
16785=obstruçao ou fuga no tubo flexivel ou seja tens de tirar o supressor ;)
mais alguma coisa apita ;)
mas o homem tinha estes erros antes de meter o supressor da EGR e depois de tirar instalar o Supressor mantem-se..
Que sera mestre?? Vi na net, tal como lhe disse, que o comum é a peça acopolada à EGR que faz parte da admissão avariar.. mas ao eleminar a EGR tambem nao se elemina este componente??
RockyBoy disse:
ele tinha este erro 19558=actuador do controlo do ar do colector de admiçao ou seja ou esta marada ou tem mau contacto
certo?
se for isso tem de trocar o actuador que esta antes a egr pois isso tem um carreto que parte e so mesmo substiuido e que passa ;)
tal como eu previa... a substituiçao do supressor nao adianta em nada a resoluçao do problema, dai o carro falhar de vez em quando...
o mestre, nao arranjas isso ao rapaz, uma peça usada a um bom preço?? é que novo aquilo manda-se para os 300€
RockyBoy disse:
Boas...
Então mas eu ao por o supressor essa peça saltou fora, se o problema fosse esse nao deveria ter resolvido?
cumps..
MM..Rings 8P disse:
Boas...
cumps..
entao se saltou fora ai esta o mal do erro isso tem uma ficha e um mecanismo ou seja a entrada de ar fica sempre aberta logo vai dar erro ;)
Sim a questao do erro eu ja percebi, mas se o carro andava a soluçar porcausa dakilo e uma ves subestituido pelo supressor nao deveria ter resolvido o problema Mestre?? :S
abraço
