Audi A3 8L 1.6
Boas, tenho aqui o resultado de um scan que fiz hoje e surjiram alguns erros, ainda não os apaguei, mas amanhã apago e logo vejo se voltam a aparecer. Se alguém souber o que significam, poupam-me umas boas horas de pesquisa! Obrigada!
Address 01: Engine Labels: 06A-906-019-AEH.LBL
Controller: 06A 906 019 E
Component: 1.6l R4/2V SIMOS HS2256
Coding: 04000
Shop #: WSC 06435
1 Fault Found:
00557 - Pressure Switch; Power Steering (F88 )
29-00 - Short to Ground
Readiness: N/A
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03140
Shop #: WSC 06435
4 Faults Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-00 - Open or Short to Plus
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
01206 - Signal for Duration of Ignition; OFF
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: Redir Fail!
Controller: 8L0 959 655 C
Component: Airbag 6 Audi D01
Coding: 00004
Shop #: WSC 06435
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Coding: 04000
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Coding: 03140
Shop #: WSC 06435
4 Faults Found:
Coding: 00004
Shop #: WSC 06435
1 Fault Found:
