Fotografia do Dia - O Topico
o deste fim-de-semana foi engraçado, o que estava em 1º lugar só ganhou por causa do acidente que ele estava a ficar sem gota :D só estratégia :p :p
2011 Hennessey Venom GT Specifications
Engine
Block
Size
Position
Compression
Redline
Forced Induction
Oiling System
Valvetrain
Fuel System
Chevrolet LS V8
Aluminum
376 CID (6.2 Liter)
Mid Longitudinal
8.8:1
7,200 rpm
Twin Ball Bearing Turbochargers
Dry Sump
OHV, 2 Valves per Cylinder
Sequential Multi-Port Electronic Fuel Injection
Power
Horsepower
Torque
Specific Output
BHP / Weight
Boost
Fuel
1,030 bhp @ 6,500 rpm (933 rear wheel hp)
972 lb-ft @ 4,200 rpm (874 rear wheel lb-ft)
166 bhp / Liter
767.23 hp per ton (2.61 lbs / hp)
16 psi (1.1 bar)
93 octane
Transmission
Type
Gear Ratios
Final Drive
Ricardo 6-Speed Manual
2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1; 0.63:1
3.36:1
Speed by Gear
Redline
1st
2nd
3rd
4th
5th
6th
7,200 rpm
68 mph
104
145
190
232
260 (6,600 rpm)
Performance
0 - 100 km/h
0 - 200 km/h
0 - 300 km/h
2.9 sec
7.0 sec
14.9 sec
Aerodynamics
Drag Coefficient
Downforce
0.36 (rear wing down); 0.43 (wing raised)
1,492 lbs @ 150 mph
Brakes
Calipers
Rotors
Brembo 6-piston (all 4 corners)
15.0 x 1.34 in Carbon Ceramic (all 4 corners)
Suspension
Type
Ride Height
KW Variant 3 Adjustable Coilover (all 4 corners)
Adjustable by 2.4 inches (60 mm)
Dimensions
Length
Width
Wheelbase
Track - Front
Track - Rear
15.27 ft (4,655 mm)
6.43 ft (1,960 mm)
110.24 in (2,800 mm)
63.46 in (1,612 mm)
63.15 in (1,604 mm)
Weight & Measurements
Curb Weight
Dry Weight
F/R Balance
Fuel Capacity
2,685 lbs (1,220 kilo)
2,524 lbs (1,147 kilo)
37/63 (empty); 44/56 (with driver & passenger)
18.5 gal (70 liter)
Wheels & Tires
Tire - Front
Tire - Rear
Wheel - Front
Wheel - Rear
235/30/20 Michelin PS2
335/30/20 Michelin PS2
8.5 x 20 in
12.5 x 20 in
