Boas, preciso ajuda na montagem desse alarme.
Carro: Audi A4 Avant TDI 1.9 130cv de 2002
Tenho quase tudo montado (funções básicas), só que tenho um problema com connector 6P que liga ao starter.
Encontrei todos os fios necessários na carrinha, mas agora os fios do alarme... :S
Aqui está a info do manual:
Red wire(No.4) - ligado.
Yellow wire(No.5) - com esse fio ligado ao starter consigo entrar em modo de programação (Valet).
agora o resto...
Deixo aqui o link para info que está no manual:
https://docs.google.com/document/d/1iYip0y4RYQzFIF5kcop20XgZVcKz6yv6mQrjWoqVP0E/edit?usp=sharing
Agradeço pela ajuda e/ou qualquer info sobre o mesmo.
Abraço.
Connect of six-terminal central block power connector
Red wire(No.4): power "+" from +12V, connect to positive battery contactor
Blue wire(No.2): car alarm system (CAS) activation control output, connect to CAS contactor of ignition lock
Yellow wire(No.5): ignition supply output No.1, connect to ignition lock terminal
Green wire(No.6): ignition supply output No.2 with programmable operating algorithm (function 7), See "Temporary system operating diagrams for remote engine starting"
Black-yellow wire (No.1): power output to starter. Connect to starting relay. If starter locking is required, cut standard wire connecting ignition lock with starter
Black-white wire (No.3) input controlling starter activation from ignition lock.Used only if it is necessary to lock starter and prevent its accidental turning during remote engine preheating, connect to 50/1 contactor of ignition lock
agora o resto...
Abraço.
