Boa Tarde hoje é a minha vez, depois de bastante leitura aqui no forum decidi começar a usar o cabo ora após a primeira leitura a pareceu-me os seguintes erros:;
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 028 906 021 GN
Component: 1,9l R4 EDC G00SG 1422
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A4 KLIMA
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 C
Component: Airbag 7 Audi DE2
Coding: 00102
Shop #: WSC 06325
4 Faults Found:
01222 - Crash Sensor Side Airbag: Passenger Side (G180)
36-10 - Open Circuit - Intermittent
44-10 - Short Circuit - Intermittent
01218 - Side Airbag Igniter: Passenger Side (N200)
32-10 - Resistance too High - Intermittent
01217 - Side Airbag Igniter: Driver Side (N199)
Address 17 -------------------------------------------------------
Controller: 8D0 919 034 E
Component: B5-KOMBIINSTRUMENT__D12
Coding: 00140
Shop #: WSC 04981
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0V2129054 D77
Coding: 00000
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 12897
Shop #: WSC 08910
2 Faults Found:
00957 - Key 3
09-00 - Adaptation Limit Surpassed
00958 - Key 4
End ----------------------------------------------------
Digam-me se os erros sao graves ou nao.
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
Readiness: N/A
Coding: 0273004132
Shop #: BB 24303
Component: A4 KLIMA
Coding: 00102
Shop #: WSC 06325
4 Faults Found:
Coding: 00140
Shop #: WSC 04981
Coding: 00000
Shop #: WSC 00000
Coding: 12897
Shop #: WSC 08910
2 Faults Found:
00957 - Key 3
00958 - Key 4
