Boa noite:
esta tarde fiz uma leitura com o vag-com na minha A4 B5 e apareceram-me os seguintes erros:
gostava de saber se sao graves
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 028 906 021 GN
Component: 1,9l R4 EDC G00SG 1422
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 0
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 C
Component: Airbag 7 Audi DE2
Coding: 00102
Shop #: WSC 06325
2 Faults Found:
01222 - Crash Sensor Side Airbag: Passenger Side (G180)
36-00 - Open Circuit
01218 - Side Airbag Igniter: Passenger Side (N200)
32-10 - Resistance too High - Intermittent
Address 17 -------------------------------------------------------
Controller: 8D0 919 034 E
Component: B5-KOMBIINSTRUMENT__D12
Coding: 00140
Shop #: WSC 04981
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0V2129054 D77
Coding: 00000
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 12897
Shop #: WSC 08910
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00957 - Key 3
09-00 - Adaptation Limit Surpassed
End -------------------------------------------------------
obrigado
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
Readiness: N/A
Coding: 0273004132
Shop #: BB 24303
Coding: 00102
Shop #: WSC 06325
2 Faults Found:
Coding: 00140
Shop #: WSC 04981
Coding: 00000
Shop #: WSC 00000
Coding: 12897
Shop #: WSC 08910
3 Faults Found:
35-00 - -
28-00 - Short to B+
00957 - Key 3
obrigado
