limpar notificação de revisão e ajustar intervalo com vag-com 311.2
  • Thread starter Thread starter anvil
andei aqui a ler valores e abrindo o vag:
17 - instrumentation > 10 - adaptation:
00 - save = reset factory
01 - 127
05 - 0
06 - 10
07 - 0
08 - 0
só existem estes valores de 0 a 99.
Alguém faz ideia de como se faz reset ao service interval?(ln 2) e (ln 1)?
Queria também saber como se alteram os valores dos intervalos entre estas verificações.
Pre-1998 models ... or if Channel 02 is not available:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter the correct channel from the list below in "Channel Number"
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of from the list below.
[Test]
[Save]
Channel 05 should be the distance until the next Oil Service.
It is in thousands of kilometers. Let's say you want the Oil
Service light to come on in 5000 miles. That would be 8000 km.
Put the value 8 into channel 05. The "standard value" used by the US
dealers would be 12 (7500 miles).
Channel 06 should be the distance until the next In-1 Service.
Same units as above. Standard value would be 24 (15,000 miles).
Channel 07 should be the time until the next In-1. In-1 lights
up based on time or distance, whichever comes first. This is in
10's of days. Standard value would be 36 for 360 days.
Channel 08 would be time until the next In-2. In-2 is based
strictly on time. Standard value is 72 for 720 days (about
two years).
fonte: Ross-Tech: VAG-COM: Audi Service Interval Reminders
Resumindo:
00 - save = reset factory >> NAO MEXER
01 - 127
05 - 0 >> centenas de km que faltam para a proxima troca de oleo
06 - 10 >> centenas de km que faltam para a proxima revisão (ln 1)
07 - >> dezenas de dias até ln 1
08 - >> dezenas de dias até ln 2
tenho de ver o livro/manual de revisões da audi para saber o que deve ser feito a cada um destes momentos.
Em vez de andares aí onde tens duvidas e mexeres secalhar em algo que nao deves e trocar valores, no vag com pagina inicial tem um menu bastante mais facil e que faz o reset automaticamente. ;) Menu: SRI reset
De um certo ano a outros anos os canais para modificar isso são diferentes.
Só se na tua versão do VAG-COM não tiveres essa opção claro. Mas para isso diz o carro em questão para o povo daqui te puder ajudar :)
Obrigado pelo apoio rapaziada.
Andei a pesquisar e entretanto encontrei a resposta. Adquiri um cabo KKL 409.1 muito barato, e que para a minha A4 de 97 chega perfeitamente. O problema foi encontrar uma versão de software que funcionasse com este cabo.
Acabei por conseguir com uma maquina virtual em VMware e a versão 311.2 do vag-com.
Nessa versão não existe esse menu, e quase todas as referencias que encontrei na net versavam esse método do menu SRI. Portanto senti-me na obrigação de documentar aqui os passos que segui.
Vou na medida do possivel explorar mais a fundo as possibilidades do interface.
Para já posso ajustar os avisos para os intervalos que me são convenientes, o que já é bom ;), e claro... fazer reset aos avisos.
