neljoe
Moderator
O teu problem está aqui:
E isso mexe com outras coisas... por ex. este erro:
Solução:
Address 03: ABS Brakes labels: Redir Fail!
Part No: 8NO 907 379 A
Component: ABS/EDS 20 IE CAN V001 Coding: 13504
Shop #: WSC 06435
2 Faults Found:
01324 - Control Module for Ali Wheel Drive (J492)
49-00 - No Communications
01314 - Engine Control Module
49-10 - No Communications - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Solução:
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
@ http://wiki.ross-tech.com/index.php/01314
