Viva,
Depois de fazer o log do vag-com, em abaixo coloco só os registos dos erros.
Alguém sabe que erros são estes?
Obrigado.
LOG VAG-COM:
28-HVAC, Rear -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0076
Serial number: 15111200040143
Coding: 00
Shop #: WSC 39129 000 1048576
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 36634CBE898657F24A-8063
1 Fault Found:
0094 - No Basic Setting
B2010 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 141678 km
Date: 2017.05.29
Time: 10:45:19
Basic setting of flap motors-Left Rear Upper Body Vent Motor: OK
Basic setting of flap motors-Right Rear Upper Body Vent Motor: OK
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Revision: 00002001 Serial number: 0169635981
Coding: 0100062020B90480832009840C0104F00000000000000000000000000000
Shop #: WSC 02391 785 00200
VCID: 76E38CBEC10617F28A-8023
Subsystem 1 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000827589
Coding: 010000
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 141724 km
Time Indication: 0
Date: 2017.05.29
Time: 11:56:18
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 141724 km
Time Indication: 0
Date: 2017.05.29
Time: 11:56:50
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 24
Reset counter: 223
Mileage: 141724 km
Time Indication: 0
Date: 2017.05.29
Time: 13:26:04
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000022451
Coding: 030000
VCID: 1D31B3120470E4AAAB-8049
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 99
Reset counter: 184
Mileage: 141678 km
Time Indication: 0
Date: 2017.05.29
Time: 10:45:24
Freeze Frame:
Bin. Bits: 00000001
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227B/0C7536486
Coding: 010003010000000001
VCID: 21498FE23808C04A8F-8075
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 184
Mileage: 142276 km
Time Indication: 0
Date: 2017.06.15
Time: 20:26:59
Freeze Frame:
Bin. Bits: 00000000 00001100
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 G HW: 4G0 035 666 A
Component: H-BN-EU H48 0484
Revision: -------- Serial number: 426BY0C7638072
Coding: 050100010003EDFF6F108F3E00000003E00001020000000000
VCID: 2C576ED64FCA1D222C-8079
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB9400P0KS
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LB8000D2
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 73
Reset counter: 184
Mileage: 142276 km
Time Indication: 0
Date: 2017.06.15
Time: 20:26:54
Freeze Frame:
Bin. Bits: 00011111 00000000
Bin. Bits: 00000000 00000000
Address 72: Door, Rear Right (J389) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HR H04 0212
Revision: -------- Serial number: --------------
Coding: 010F14204000628002080002
VCID: 44872676C75AF562C4-8011
5 Faults Found:
01482 - Motors for Central Locking
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 89
Reset counter: 224
Mileage: 141678 km
Time Indication: 0
Date: 2017.05.29
Time: 10:45:17
02131 - Child Safety Lock Motor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 73
Reset counter: 222
Mileage: 141678 km
Time Indication: 0
Date: 2017.05.29
Time: 10:45:17
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 8
Reset counter: 184
Mileage: 141927 km
Time Indication: 0
Date: 2017.06.04
Time: 16:01:13
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 3
Fault Frequency: 27
Reset counter: 184
Mileage: 142065 km
Time Indication: 0
Date: 2017.06.10
Time: 14:10:11
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 27
Reset counter: 184
Mileage: 142065 km
Time Indication: 0
Date: 2017.06.10
Time: 14:10:11
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051002127
Coding: 04C0B8181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 275D91FA5E2C3E7AC1-8073
1 Fault Found:
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 141678 km
Date: 2017.05.29
Time: 10:45:19
Outside air temperature: 21.5 °C
Voltage terminal 15: 14.2 V
Control Module temperature: 34.0 °C
