tenho um A4 motor awx 1.9 tdi 130cv e ja a faltar a potencia no motor fiz um scan e deu-me estes erros
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 JQ
Component: 1,9l R4 EDC 0000SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E23A171975 AUZ6Z0B0241594
2 Faults Found:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 J
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00001
Shop #: WSC 34495
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
1 Fault Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 07008
Shop #: WSC 63351
1 Fault Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D08
Coding: 00060
Shop #: WSC 63351
já trocei o medidor de massa de ar e a válvula N75 mas o problema continua alguem me pode ajudar?
Obrigado e abraços a todos
Coding: 00002
Shop #: WSC 63351
2 Faults Found:
P0101 - 35-00 - -
P1556 - 35-00 - -
Readiness: N/A
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Coding: 00012
Shop #: WSC 63351
Coding: 00001
Shop #: WSC 34495
1 Fault Found:
Coding: 07008
Shop #: WSC 63351
1 Fault Found:
Coding: 00060
Shop #: WSC 63351
