Boas
Ja fiz o log, mas não percebi muito bem, aquilo tem varios grupos, e não sei qual ei-de escolher, o que mais queria ver era os dos injectores... Mas so aparece uma coisa de injectores INJECT.QT....
Vou por aqui os logs, estão é um pouco esquesitos...
Sunday,22,October,2006,18:58:38
038 906 019 FP ,,1.9l R4 EDC 0400SG 1467,
,Group A:,'003,,,,Group B:,'001,,,,Group C:,'002
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,Engine speed,Throttle pos,Operating Cond/AC,Coolant Temp
,TIME,790-870,230-310,210-350,40-75%,TIME,790-870,3.0-9.0,3-8 °Ck.,80-110°C,TIME,790-870,0%,speed/throttle/AC,80-110°C
MARKER,STAMP, /min, mg/R, mg/R, %,STAMP, /min, mg/R, CF,°C,STAMP, /min,%,,°C
,0.95,861,335.0,357.7,48.2,1.36,1176,9.3,6.6,80.1,0.53,861,0.0, 0 1 0,80.1
,2.16,1932,360.0,357.7,47.4,2.56,2646,28.8,9.7,80.1,1.76,1554,15.7, 0 0 0,80.1
,3.36,5103,850.0,681.1,4.8,3.76,4536,0.0,-3.1,80.1,2.96,4137,58.4, 0 0 0,80.1
,4.56,2646,370.0,568.4,4.8,4.96,1995,0.0,0.5,80.1,4.16,3465,0.0, 0 1 0,80.1
,5.76,987,335.0,372.4,53.4,6.16,966,0.0,3.6,79.2,5.36,1470,0.0, 0 1 0,80.1
,6.98,924,335.0,279.3,50.6,7.38,903,2.7,6.1,79.2,6.58,903,0.0, 0 1 0,79.2
,8.18,1701,850.0,411.6,4.8,8.59,3129,34.3,13.8,79.2,7.78,903,0.0, 0 1 0,79.2
,9.42,3717,850.0,661.5,4.8,9.84,2856,0.0,-1.0,79.2,9.01,4620,0.0, 0 1 0,79.2
,10.64,1638,320.0,490.0,49.8,11.04,1155,0.0,3.6,79.2,10.24,2184,0.0, 0 1 0,79.2
,11.84,924,335.0,328.3,52.2,12.24,924,1.4,5.6,79.2,11.44,882,0.0, 0 1 0,79.2
E outros que fiz ao Inject.QT
Sunday,22,October,2006,19:03:27
Marker,Group A:, Not Running,,,,Group B:,'001,,,,Group C:, Not Running
,,,,,,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,,,,
,TIME,,,,,TIME,790-870,3.0-9.0,3-8 °Ck.,80-110°C,TIME,,,,
MARKER,STAMP,,,,,STAMP, /min, mg/R, CF,°C,STAMP,,,,
,,,,,,0.00,903,1.1,5.6,78.3,,,,,
,,,,,,0.40,903,12.6,6.6,78.3,,,,,
,,,,,,0.80,1869,17.3,8.7,78.3,,,,,
,,,,,,1.20,2772,17.0,6.1,78.3,,,,,
,,,,,,1.60,3696,5.8,0.5,78.3,,,,,
,,,,,,2.00,3318,0.0,-2.0,78.3,,,,,
,,,,,,2.40,2604,0.0,-1.5,78.3,,,,,
,,,,,,2.80,1974,0.0,0.5,78.3,,,,,
,,,,,,3.20,1449,0.0,2.6,78.3,,,,,
,,,,,,3.60,1281,7.4,6.6,78.3,,,,,
,,,,,,4.00,1554,6.3,6.1,78.3,,,,,
,,,,,,4.40,1890,5.8,5.6,78.3,,,,,
,,,,,,4.80,2142,7.4,5.1,78.3,,,,,
,,,,,,5.20,2961,29.1,10.2,78.3,,,,,
,,,,,,5.60,3633,0.0,-1.0,78.3,,,,,
,,,,,,6.00,2877,0.0,-1.0,78.3,,,,,
,,,,,,6.40,2226,0.0,-1.5,78.3,,,,,
,,,,,,6.80,1659,0.0,2.0,78.3,,,,,
,,,,,,7.20,1176,0.0,3.6,78.3,,,,,
,,,,,,7.60,882,3.6,6.6,78.3,,,,,
,,,,,,8.00,924,1.1,5.6,78.3,,,,,
,,,,,,8.40,1029,22.2,7.1,78.3,,,,,
,,,,,,8.80,2415,26.1,10.2,78.3,,,,,
,,,,,,9.20,4011,3.8,1.5,78.3,,,,,
,,,,,,9.60,3381,0.0,-2.0,78.3,,,,,
,,,,,,10.00,2583,0.0,-1.5,78.3,,,,,
,,,,,,10.40,1953,0.0,0.5,78.3,,,,,
,,,,,,10.80,1428,0.0,3.1,78.3,,,,,
,,,,,,11.20,987,0.3,4.1,78.3,,,,,
,,,,,,11.60,924,2.7,6.1,78.3,,,,,
,,,,,,12.00,903,2.5,6.1,78.3,,,,,
,,,,,,12.40,966,0.0,3.6,78.3,,,,,
Outra coisa muito esquesita a meu ver foi que, a olho no, no ponteiro das rpm este parece estar a bater no traço das 600rpm, mas pelo vag-com, como poderás ver no log, esta a 860rpm....
