O pai google faz milagres!!
Ora cá está:1 parte--We turn a radio cassette player. The display must turn "SAFE" press the button at the same time "TP" and "RDS" and keep PC55XXZ until the display turns the legend "1000" (2-3 seconds) . Press "1", "2", "3" and "4" enter code. The "1" is the first digit code, the button "2" is the second, etc. Each click of a button changes the code to figure 1. After verifying that the code is correct introduced simultaneously pressing and holding the button PC55XXZ "TP" and "RDS (2-3 seconds) . A300 goes into operation
2 parte--The explicit radio "Chorus" production "Blaupunkt" can not control changer, but because it is made at one with the Hebei "Concert", which is the function of CD changer, it is possible to develop a "Chorus" that he, too, could manage changer. The basic cost of such services in our shop-1200 rubles. Once finalized by cassette recorder can be connected R700 staff or through an adapter, six disc changers Alpine (CHM-S630 or CHA-S634). Look to the cost and compatibility of the adapter can link
3 parte--Some Hebei "Concert" and "Chorus" from Blaupunkt time is not work volume, or stop working. Repair shops in non usually is not. At best, not only simple methods for some time to get rid of this problem, which again is a problem. This is because all of the adjustments volume recorded in the nonvolatile memory controller. This memory has a limited number of write cycles, and it would be prudent to write to you Hebei to the volume levels recovering when you turn, and developers decided BLAUPUNKT record of all volume control knobs turning in any volume. And as a result, in a moment of quite decent Hebei stop working volume. Our engineers found correct this error and are replacing faulty microcontrollers to the new, with an amended programme. For more information about this error developers can be read in the article "The problem of some radio models, Audi Chorus" and "Audi Concert", or bombs, from the company Blaupunkt. "
Agora é assim isto não diz grande coisa de util nada que nos já não soubesse-mos.
