Rádio e VAG-COM
Eu penso que sim, penso, porque nunca o fiz... Amigo passa na Audi e pergunta se o rádio tem salvação, assim partes logo para outra! Por perguntar não precisas de pagar!!! ;)
Estive a procurar dos Posts dele... e sendo um 8L deverá ser um CONCERT:
Então fazes assim:
Other Preferences & Configurable Options
The following is the procedure on how to access some other preferences that you may set in the Audi Concert radio.
-Turn off radio.
-While pressing and holding the FM2 or TP button (whichever is appropriate for your radio version), turn on radio.
-The display will show a parameter that could be adjusted.
-Turn the volume control knob to change the setting.
-Press the FM2 or TP button to advance to the next adjustable parameter and you can use the volume knob in the same way. Repeat this until it cycles back to the first mode.
-When you are done, turn off radio, the setting will be remembered the next time the radio is turned on.
-The table below shows a list of parameters that can be adjusted in this manner:
Parameter Description
SVC (or GALA) Speed-sensitive Volume Control (auto-volume compensation) effect
VOL Turn-on volume setting
SENS Station-scan sensitivity (DX/LOcal)
RM Radio Monitoring (whether radio should come on
while cassette is rewinding or fast-forwarding) (OFF/ON)
NAV Navigation system audio mute amount
TA Traffic Announcement volume. The volume of traffic announcements (independent of music volume). This is applicable to radios with this capability, and operated in an area with such a service.
@ http://www.ibiblio.org/tkan/audi/radios/concert.html
:green: Isso e t€€€mpo! Só assim para me matar o bixo de uma vez só, para quanto €´s poderia ir uma brincadeira dessas?
