Socorro!! Login e coding de abs audi a6 1.9tdi
BOAS! Andava eu a tentar acertar os ponteiros do quadrante do meu argolas com o sistema vag-com 311.2 quando esta porcaria deu erro e acendeu a luz do ABS. reiniciei o pc a fui ver o registo de erros! que era este:
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Controller: 038 906 019 BS
Component: 1.9l R4 EDC 0200SG 1253
Coding: 00002
Shop #: WSC 02325
WAUZZZ4BZ1N111674 AUZ7Z0Y1743712
1 Fault Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 AE
Component: A6-Klimavoll
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 920 932 Q
Component: C5-KOMBIINSTR. VDO D12
Coding: 00140
Shop #: WSC 00012
No fault code found.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 D
Component: Zentralverriegelung D34
Coding: 06757
Shop #: WSC 02325
6 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Left Rear Door
59-00 - Can't Unlock
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
End -------------------------------------------------------
agora nao sei o fazer a minha vidinha!
ja fui ao site da ross-tech mas nao descubro o login
da sempre o erro (login lost due to dropped session)
tou f****o!! se alguem me pudesse ajudar... muiito obrigado:D
coding e login resolvido neste link: Audi A4 (8D) Brake Electronics (Bosch 5.3 ABS/EDS/ASR/ESP) - Ross-Tech Wiki
ter atenção ao diametro da jante e tipo de travões que era o k me estava a dificultar o coding
mesmo assim permanecem estes erros k ainda nao consegui resolver:
Coding: 00002
Shop #: WSC 02325
Coding: 06255
Shop #: WSC 00002
Component: A6-Klimavollautomat D65
Coding: 00043
Shop #: WSC 02325
Coding: 00140
Shop #: WSC 00012
Coding: 06757
Shop #: WSC 02325
3 Faults Found:
35-00 - -
sou mesmo esteio lool aqueles erros são dos testes k fiz ás portas lool ta tudo fine agora! espero k sirva de ajuda a alguem=)
cumps..
não devias seguir o coding do A4 8D... (B5)
o vag recomenda o coding... e no teu caso deve ser 00012
Alem disso tens de "ensinar" o ESP
Eu sou um bocado leigo nisto peço desculpa se tiver e dizer bacoradas, mas no procedimento de coding daquela pagina da ross-tech referencia o modelo do chassis do meu carro e tipo de travões, portanto deve ser o certo, pk o procedimento de descobrir o login é o mesmo k o procedimento para descobrir o coding!
E é k o vag-com so me aceita aqueles valores, se inserir outros a ligação falha, aparece a mensagem (login lost due to dropped session).
quanto ao ensinar o esp, seria fazer o teste no módulo de ABS, e depois carregar no travão ate o simbolo do esp desligar e depois dar uma volta para o simbolo do ABS desaparecer certo?
Ah outra coisa, as portas de tras funcionam bem, agora, mas houve uma altura k abria a porta de tras do lado do passageiro e nao acendia a luz, o k acontece agora na porta da frente do lado do passageiro mas esta nunca mais funcionou direito!! sera o switch k foi a vida? obrigado à atenção dada aos meus problemas, esperu um dia poder ajudar tambem! cumps, rikardo!!
