Re: PolishWorks 1,9TDI Quattro 165ps 18" project finished p.10
Hi friends
I invested in a new lens to the camera. I bought a cheap used "super Takumar 1:1.4 50mm. If anyone is interested in photography, this really recommend you try this lens
some pictures
Body Sony NEX5N
Unfortunately the rear seat of the sedan, it is not compatible in Avant
In addition, there is no plug-in support of seat belt tensioner. Lighted a lamp Air-Bag. Tomorrow I'll have to give the seat to the backrest an upholsterer.:roll:
I bought a complete rear seat of the avant, it removes the base construction. Removed element is installed in the seat sedan.
This will can be mounted on the factory mounts avant, and will mount a vertical grid
At the end of the week should already be receiving
Unfortunately, it was impossible to mount the back of a sedan. There were a lot of technical problems, for example. sensor belt tensioner.
I was able to replace the seat with a friend. Just bought a half-leather version of avant sport package
In the meantime, a second set of suspension hunted, this time it's KW
Hello
Recently I had a clutch failure. On 4 and 5 could not run away quickly accelerate.
The decision was quickly
I bought a new complete clutch of 130PS Audi A4 B6. If you have any problems with the clutch, I would recommend this operation, the clutch is P&P. Clutch is stronger than the serial mounted in 1.9 (110-115PS). No problem, move the torque of 380nm
And autumn session
I did this car already 100 thousand km and 70 thousand after engine modifications8)
Quattro drive takes a little power, but winter is a fantastic ride. Perhaps I'll even modify the engine, change injectors and turbochargers, or engine swap PD...
