Vag-com - ajuda com avarias
Buenas, poderiam me orientar nos erros que apareceram??
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 06A 906 018 CJ
Component: 1.8L R4/5VT MOTR HS D01
Coding: 04000
Shop #: WSC 00000
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00040
Shop #: WSC 00000
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
29-00 - Short to Ground
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 M
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 02544
Shop #: WSC 00113
XXXXXXXXXXXXXXXXX AUZ7Z0E2716719
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D16
Coding: 14188
Shop #: WSC 00137
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 56 -------------------------------------------------------
Controller: 8L0 035 195 N
Component: symphony II PM6 0410
Coding: 05001
Shop #: WSC 00000
End -------------------------------------------------------
isso poderá ser erros antigos, ou ficaram armazenados devido a alguma intervenção, apaga-os e depois de fazeres uns kilometros com a viatura, liga novamente o VAG, e vê se voltaram, e depois volta cá para o pessoal ajudar, caso o VAG os detete novamente..
Obrigado Vick_79, o problema que estou seria quando abro qualquer porta aparece que abro junto no cb a porta do motorista...
E as luzes de cortesia vermelhas e brancas ora acente ora não acende..
mas apaga o erros, e depois volta cá ;)
Buenas,
Apaguei os erros, passou alguns dias e novamente estou aqui:
Coding: 04000
Shop #: WSC 00000
Coding: 0004097
Shop #: WSC 00000
Coding: 00040
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Coding: 02544
Shop #: WSC 00113
Coding: 14188
Shop #: WSC 00137
2 Faults Found:
35-00 - -
28-00 - Short to B+
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
Coding: 05001
Shop #: WSC 00000
Alguém pode me ajudar??
o alarme deve ter acionado, e as luzes interiores, estão a funcionar corretamente?
As luzes das portas não acendem, as vermelhas e brancas que ficam nas portas quando abertas...
Boas sou novo no nisto mas tenho um a4 1.9 tdi b5 95 e a soufagem esta me a dar cabo da cabeça ja lhe limpei o radiador ja lhe mudei o anticongelante , os motores trabalham bem e troquei o filtro da soufagem e continua a nao me dar ar quente ja nao sei o que fazer uma ajudfa ai de alguem por favor
Antes que começes para aí a disparar por tudo quanto é tópico com a mesma pergunta, procura primeiro informação para o teu problema pelos vários tópicos do forum, se não ficares esclarecido, abre então um com o tua dúvida... ;)
E o motor aquece até aos 90C°?
Ja verificaram o termostato?
Boas, eu também tenho alguns desses erros no meu a4 na parte eléctrica, e tenho esse problema das luzes acenderem e apagarem e dar sinal de porta do condutor aberta quando abro a do pendura..Chegaste a alguma conclusão se era fio trilhado ou algum problema eléctrico no quadrante ou assim? Abraço
