Bem deu mas tive de configurar a porta com nos gestores de dispositivos.
bem deu me uma carrada de erros. Gostava quem soubesse e ja teve erros iguais se me pode dar uma ajuda
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 028 906 021 F
Component: 1,9l R4 EDC SG D2I
Coding: 00000
Shop #: WSC 00000
4 Faults Found:
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00741 - Brake Pedal Monitoring
65535 - Internal Control Module Memory Error
00-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
1 Fault Found:
00526 - Brake Light Switch-F
36-00 - Open Circuit
Address 08 -------------------------------------------------------
Controller: 4A0 820 043 D
Component: Klima-Vollautomat D05
Coding: 00060
Shop #: WSC 02315
11 Faults Found:
00786 - Temp Sensor in Headliner (G86)
30-00 - Open or Short to B+
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to B+ - Intermittent
00779 - Outside Air Temp Sensor (G17)
00800 - Temperature Sensor at Fresh Air Blower (G109)
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
01274 - Air Flow Flap Positioning Motor (V71)
01270 - A/C Magnetic Clutch (N25)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 A
Component: B5_KOMBIINSTRUMENT D02
Coding: 00140
Shop #: WSC 01539
No fault code found.
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0S1247984 D76
Coding: 00000
Shop #: WSC 00000
End -------------------------------------------------------
