The liquidCUBE is a versatile hand held diagnostic tool that can be used across the VAG range of cars using KW1281, KWP2000, KWP2089 diagnostic coms on the OBD2 port.
It can either be used as a hand held unit or mounted using a magnetic suction screen mount.
The liquidCUBE provides all of the functions available on the integrated liquid versions but with added portability. The unit is housed in a sturdy aluminium case and simply plugs into the cars OBD2 diagnostic port, its plug and play.
Features
Main Menu
Gauge Display
Graph Display
G force
Speed timing
Faults and adaptations
Multigauge (Coolant, Air, N75 and Boost)
Setup
Sub Menus
Gauge Display
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Oil temp
Graph data
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Missfire
Dyno plot
Timing Correction plot
Speed/RPM display
G - Force Display
Bar Graph
Left
Right
Acceleration
Deceleration
http://racediagnostics.com/cms/
Speed timing
0-60mph acceleration timing
0-100mph acceleration timing
Faults and Adaptations
Display and Erase Fault Codes
Big turbo setting for up to 500hp engines
English, French, Finnish and German language versions
Imperial or Metric units
