Pessoal ainda sobre o assunto da luz amarelo do motor.
Pois bem, apos a colocação do tal chip o carro dormiu na rua sö duas vezes e foi nessas duas vezes, nessas duas manhas a 9graus d temperatura que a luz acendeu. Intervalo de um mes entre os 2 avisos. Sera mesmo algo? sera de o chip fazer mais fumo e ser obrigado a entrar logo na AE ?
deixo aqui os erros
Part No SW: 03G 906 021 RD HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1889
Revision: --H07--- Serial number: AUX7Z0H1FNR043
Coding: 0000071
Shop #: WSC 00392 223 05043
1 Fault Found:
000385 - Fuel Temp. Sensor A (G81): Implausible Signal
P0181 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Mileage: 144005 km (
agora tem 146mil km)
Time Indication: 0
Date: 2013.09.22
Time: 21:58:48
Freeze Frame:
RPM: 1701 /min
Speed: 79.0 km/h
Load: 20.4 %
Voltage: 14.36 V
Temperature: 16.2∞C
Temperature: 87.3∞C
Temperature: 128.7∞C
Readiness: 1 1 0 0 0
____
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K08221126A
Coding: E9807F060002022102
Shop #: WSC 06314 000 00000
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 51
Mileage: 143083 km
Time Indication: 0
Date: 2013.09.07
Time: 15:25:48
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 222
Mileage: 143083 km
Time Indication: 0
Date: 2013.09.07
Time: 15:29:06
_______
