Boas ... Ora entao cá vai o relatorio...
Sunday,23,September,2012,19:29:17:37412
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E75A501869 Mileage: 245790km/152726miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 AF
Component: 2.5l V6 TDI G000AG 0060
Coding: 02007
Shop #: WSC 51870
VCID: 69D3CC003C5D
Subsystem 1 - Part No: 00008059
Component: 130 106MC318_1.V14844427582
WAUZZZ8E75A501869 AUX6Z0D0437437
1 Fault Found:
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
Readiness: 0 1 X X X
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E0 910 159 F HW: 01J 927 156 HT
Component: V30 01J 2.5lTDI RdW 0030
Revision: 00000006 Serial number: 00000000849801
Coding: 0000001
Shop #: WSC 73041 142 01625
VCID: 2C5D7514F32F
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 254
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
RPM: 1120 /min
RPM: 60 /min
(no units): 3.0
Torque: 62.0 Nm
Temperature: 36.0°C
T.B. Angle: 16.8°
Bin. Bits: 1010 0 0
18201 - Transmission Output Speed Sensor 2 (G196): No Signal
P1793 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
RPM: 2496 /min
RPM: 1230 /min
(no units): 30.0
Torque: 138.0 Nm
Temperature: 83.0°C
T.B. Angle: 0.0°
Bin. Bits: 1010 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004518
Shop #: WSC 06325 000 00000
VCID: 2649873CEDC3
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4022
Hex Value: 0x00FF
Hex Value: 0xFFB0
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AK
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6AD1B30C395B
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3B7F46480641
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
30-00 - Open or Short to Plus
01498 - Bulb for Parking Lamps; Right (M3)
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M002UPGI
Coding: 0033622
VCID: 3B7F46480641
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 01042
Shop #: WSC 06325
VCID: 418334A064AD
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 B HW: 8E0 920 931 B
Component: KOMBI+WFS 3 H12 0020
Revision: 0020 Serial number: AUX6Z0D0437437
Coding: 0006041
Shop #: WSC 00001 001 00001
VCID: 27578A38EAC9
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
VCID: 356B50702065
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BQ
Component: Komfortgerát T01 3132
Coding: 07024
Shop #: WSC 06325
VCID: 810374A0A42D
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01011
Shop #: WSC 06325
VCID: 28558904E7D7
desde já obrigado
