[A4 B7] Audi a4 avant 2.0 tdi quattro s-line
Re: AUDI A4 AVANT 2.0 TDI QUATTRO S-LINE 170cv
boas!!
Queria pedir uma explicação gostava de saber qual a marca do injectores que estao na minha carrinha alguem sabe como ver pelo vag-com??
ontem fiz um scan e apareceu aluns erros alguem me pode dizer o que querem dizer vou colocar ai o relatorio.??
cumps
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E17A097552 Mileage: 151820km/94336miles
Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
Component: R4 2.0l PPD1.3 G 9971
Revision: --H33--- Serial number:
Coding: 0000172
Shop #: WSC 00131 211 85595
VCID: 74E3D8E36E2B
1 Fault Found:
004708 - PD Unit Injector: Cylinder 2 (N241): Regulation Range Exceeded
P1264 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2272 /min
Torque: 248.0 Nm
Speed: 76.0 km/h
74.88 %
Text: 5.500 uF
Text: 14.75 mJ
Text: 12 mJ
Raw, Form. N/A: 000 000 000
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004405
Shop #: WSC 06335 000 00000
VCID: 2E570A8BC087
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6DD5CD870D01
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 10021
Shop #: WSC 06335
VCID: 3D753DC71DE1
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3J7C2
Coding: 0030712
VCID: 3B7133DF03F5
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04042
Shop #: WSC 06335
VCID: 418D41376119
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 P HW: 8E0 920 931 P
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0007011
Shop #: WSC 24862 000 1048576
VCID: 356525E725D1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0650
Revision: 01S Serial number: AUZBZ7F1184505
Coding: 0301717
VCID: 2C530083F69B
3 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 16
Reset counter: 173
Time Indication: 0
Date: 2013.07.20
Time: 13:36:24
Freeze Frame:
Mileage: 655350 km
Count: 510
Clock: 18:11
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 173
Time Indication: 0
Date: 2005.02.10
Time: 00:00:20
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 00:07
00857 - CD Changer Unit (R41)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 173
Time Indication: 0
Date: 2013.07.17
Time: 11:21:46
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBD1439FB315
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
81-00 - Open
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07018
Shop #: WSC 06335
VCID: 79FDE9D74949
Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3D753DC71DE1
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301717
VCID: 2C530083F69B
3 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 173
Time Indication: 0
Date: 2013.07.20
Time: 13:36:24
Freeze Frame:
Mileage: 655350 km
Count: 510
Clock: 18:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 173
Time Indication: 0
Date: 2005.02.10
Time: 00:00:20
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 00:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 173
Time Indication: 0
Date: 2013.07.17
Time: 11:21:46
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020625
Coding: 0000114
VCID: 316D11F7D1B9
Assim a primeira vista parece-me que tens um injector com avaria na parte eléctrica :| :| . Que é costume nestes motores.
Mas informa-te bem acerca da acção de chamada do teu motor, a minha b7 também é de 2006 e estava na lista. Troquei 3 deles pois um já tinha sido trocado.
Antes de mais quero dizer que tens aí um B7 à homem :)
Já agora lanço aqui um pergunta aproveitando uma informação do relatório de erros que apresentaste, o que indica esta informação:
Freeze Frame:
Mileage: 655350 km :o :o:o:o
acerca disso
Freeze Frame:
Mileage: 655350 km
tambem não sei o que significa.
cumps
Se não estou em erro...
Foi na altura em que o erro apareceu, ou seja apareceu quando o carro tinha 65 mil km, desde então nunca mais foi feito nenhum diagnostico, logo o erro nunca foi apagado
Pois. Não sei. Entretanto também tenho de fazer um scan no meu logo te digo se isso é os kms ou não! O meu também cortaram os kms, mas não tanto!
No Meu Seat eram os km ao qual apareceu a avaria e batia certo com o quadrante :S
Já existe algum esclarecimento adicional sobre a situação?
Entendidos em VAG chamados à recepção :)
Boa noite, se vocês fizeram uma pesquisa isso é um erro comum, se não todos os carros teriam esses Kms.
Nao sei a que se refere o código nem consigo encontrar.
Abraços
Boas depois de algum tempo sem vir ao forum hoje recebi uma encomenda para começar a preparar a minha carroça.
Chegou-me o aileron trazeiro agora como ja tenho tambem a grelha s-line finalmente vai tudo para pintar amanha e para o sitio. o parachoque teve que levar um pouco de bricolage pois nao tinha os furos para lava farois, e a moldura da grelha tambem foi um pouco de bricolage pois comprei enganada.
Mas ficou tudo 5 estrelas. Depois coloco aqui o resultado final.
cumps
Amigo tive a ver ler que a tua carrinha não está incluída na lista de chamada dos injectores, a tua carrinha é importada ou nacional?
Boas amigo
Sim a minha carrinha é importada.
A cerca de 1 mês liguei para a audi em Faro e ai disseram-me o contrario da audi em Portimão que a carrinha estava na lista para troca de injectores.
Levei la estiveram a ver e disseram-me que tinha 3 injectores para mudar pois 1 ja tinha sido mudado.Entretato ja fui la mudalos e noto uma diferença para melhor na carrinha.
cumps
