Re: Audi S3 Quattro (erros vag com)
Bem hoje pela 1a vez ligei o vag com ao argolas. e apareceram.me estes erros:
Address 01: Engine Labels: None
Part No: 8L0 906 018 N
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 06435
VCID: 3A71434C264486E
3 Faults Found: 17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 930 B
Component: AB-KOMBIINSTR. VDO D09
Coding: 01044
Shop #: WSC 00000
VCID: 2D5B7810E70A216
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D11
Coding: 15178
Shop #: WSC 06435
VCID: 39735C4023428D6
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
foram estes e nao sao poucos
alguem me pode dar uma Boa ajuda para resolver isto. viste que tem aqui um ou outro que nao convem andar assim
depois de ter feito o primeiro scan nao consegui mais voltar a fazer outro :S
